LS2 90mm/04 TAC Module Teaser
Old Apr 17, 2007 | 04:56 AM
  #71
WODY's Avatar
bitchin'
thanks
Old Apr 17, 2007 | 05:47 AM
  #72
wkdivr's Avatar
Put me on the list, too. PM sent
Old Apr 29, 2007 | 02:39 PM
  #73
cyazo6's Avatar
Any more ready to ship out?
Old Apr 29, 2007 | 05:14 PM
  #74
DrX's Avatar
DrX
Sorry, there aren't. But there will be a bunch when they are. Supply issues. I was told that my material was finally shipping over a week ago. Then I get an email on Thursday asking how I want it shipped because it can't go the way I wanted?? Still waiting to hear back on that. Not much better luck with the other supplier that I ordered from simultaneously. Researching alternatives while I am waiting because this is getting ridiculous.
Old Apr 29, 2007 | 05:26 PM
  #75
kbracing96's Avatar
You don't happen to have a stock TAC module for an 04 would you? I need one and a stock wiring harness for the 04 5.3 going in my dads '72
Old Apr 29, 2007 | 07:04 PM
  #76
supersub's Avatar
asleep at the wheel over here,also interested.I currently have the 02 tac withe the ls2 tb and speartech adapter harness.will that work or will i have to swap back the 03 z71 5.3 tac to make it work,and by the way,did you ever have a flat spot in the trottle between 1600-2200 rpm at a cruise try to pass and it would fall on its face showed -10*and 820'so2 readings,pulled timing and added fuel to comp but still falls slightly then pulls thru with little detonation,is this part of the typical 90mm mod problems???it would be nice to get it back to even keel again... keep up the good work.
Old Apr 29, 2007 | 07:07 PM
  #77
DrX's Avatar
DrX
Sorry, I don't.
Old Apr 29, 2007 | 07:36 PM
  #78
DrX's Avatar
DrX
You will have to swap back to your OE TAC module. I have had some issues with the engine loading up similar to what you describe after installing the Radix. Don't recall if it was there prior to the 90mm install or not. I had dealt with it in the tune(TCC/shift/kickdown tables).
Throttle position data is a significant factor in engine/transmision management, so incorrect data can result in some undesirable behavior.
Old Apr 29, 2007 | 09:06 PM
  #79
CHarris's Avatar
I see Dr X is having some problems with delays... give him some time folks. The end product is worth the wait! I've got about 200+ miles on mine and love it!
Old Apr 29, 2007 | 09:30 PM
  #80
cyazo6's Avatar
Want to sell it? JK!
