LS2 90mm/04 TAC Module Teaser
Old May 26, 2007 | 11:47 AM
  #111
CHarris's Avatar
Originally Posted by moregrip
any before and after logs?
Logs would not have told the story as I was still in the midst of refining the tune. My MAF is maxed out at about 4300 rpms now. I am seeing an additional 1 psi though after the TB controller swap and some further fuel tuning. My LS2 TB is fully ported, too.
A increase in boost may not happen on a smaller blower (i.e. mp 112), but it might help on your 122 if it flows all its said to flow.
All in all, I'm still very happy with the Dr. X mod!
Old May 26, 2007 | 12:09 PM
  #112
moregrip's Avatar
what a rush!
we saw an increase in boost when we did this mod a few years back on the 112. I was curious about IAT's, you didn't see a change?
Old May 26, 2007 | 12:45 PM
  #113
DrX's Avatar
DrX
Just a point of interest for anyone concerned with flow dynamics...... Aside from the larger opening, I have read that the flow over the blade does not begin to smooth out(laminar flow) until you get past 85% TP. Not sure if this is also a factor in any performance increases being seen/felt with this mod.
Old May 27, 2007 | 08:06 AM
  #114
BigBlackAv's Avatar
I got mine on this weekend...and it worked great...easy install, I wish this thing was around when i got my 90mm TB.
I was very impressed in how much more it opened...i forgot my digital camera at work but I used a disposable .... i'll go to walgreens and get it developed in digital and get some pics up as soon as i can.
Nice work DrX, I love it!
Old May 27, 2007 | 08:20 AM
  #115
03sierraslt's Avatar
So how much are they?? Or did I miss that somewhere?
Old May 31, 2007 | 08:54 PM
  #116
DrX's Avatar
DrX
Throttle response also appears to be smoother and with less lag in these comaparison vids. I don't miss the high pitched whine either.
Old May 31, 2007 | 08:58 PM
  #117
2004SSS's Avatar
wow that whine is very annoying. i shoul dfind out if it works on a tbss/ssr 90mm this weekend.
Old May 31, 2007 | 09:09 PM
  #118
cyazo6's Avatar
Do you think there is a need or benefit to retune your truck after the install of this harness?
Old May 31, 2007 | 09:51 PM
  #119
DrX's Avatar
DrX
I would bet that it won't, but you can give it a try.
Old May 31, 2007 | 10:03 PM
  #120
DrX's Avatar
DrX
It's not necessary but if you were going to be tuning anyway, I would do it after the install as you will have more airflow potential. Wouldn't hurt to reset the throttle area conversion factor to something more appropriate for the 90mm too. Then there won't be as much initial idle learning required.
