lq4 + tvs2300, LS6 cam or ls9 cam?
Old Nov 1, 2015 | 07:37 PM
camarokid6771's Avatar
Grab some LS3 heads while you're at it and crank up the boost.
my lower tub is for ls1 port heads. can I get a lower tub that will bolt up ls3 heads and reuse the upper and leave the blower where its at? I started with the ls2 gto blower
id feel guilty if I hurt a custom cam in a $100 through away longblock
I guess I should also mention I was gonna run the 80e stock convertor till I get a real motor assembled. should be painfully tight LOL
Old Nov 1, 2015 | 08:21 PM
ZO6Ted's Avatar
Originally Posted by terravast4
i agree...i even feel my gt2-3 is on the small side. wish i went bigger
That's not a bad fit for your setup though. Remember Trever 1t? It was a bad little truck for the time!
Old Nov 2, 2015 | 12:49 PM
terravast4's Avatar
it is a good set up..one thing i like is its strong even out of boost..just curious what there is to gain on a maggie with a bigger blower cam or if there is any more gains to be had
Old Feb 28, 2016 | 07:18 PM
just as an update, I ended up sticking a LS6 cam in there. also tore the motor down to regap the rings and have a keyway cut in the crank. ended up using LS9 head gaskets and ARP head studs
Old Feb 28, 2016 | 08:01 PM
Wolftrk99's Avatar
Was gonna say if its a learning experience toss the ls9 in there as its designed for a supercharger anyway.... Bit im too late.... Lol
08 pimpala ss
Oct 19, 2015 08:41 AM
KleanKustoms
Oct 14, 2015 09:50 PM
Wolftrk99
Oct 2, 2015 08:17 AM
