Low mount turbo
Old Sep 30, 2012 | 05:48 PM
BUTTERB30's Avatar
Default Low mount turbo
HEY my fellow turbo lovers i have a question. So ive pretty much got all my kit ready for install but im curious to know since im running a low mount right under the passenger side, right beside the oil pan can i or can i not just run the turbo return line thru the oil drain ??
Old Sep 30, 2012 | 06:35 PM
Ferocity02's Avatar
I'm guessing there isn't enough height between the turbo oil drain and the oil level in the pan to get the oil to drain properly, you may need a pump.
Old Sep 30, 2012 | 07:03 PM
nonnieselman's Avatar
If you had some pics it would prolly help. You need the bottom of the center section about as high as where the oil pan meets the block caus the oil level is prolly an inch above the low oil level sensor. You need the turbo a lil higher than that so it can drain and free flow.
ZO6Ted's Avatar
Of course you know, you are required to post pics of the build
Old Oct 1, 2012 | 05:42 AM
BUTTERB30's Avatar
I DEF WILL post more pics as soon as i can thanks guys
zblee
63
Jun 10, 2023 01:25 PM
Wareagle23
Aug 8, 2015 10:06 AM
Jake99
Aug 8, 2015 07:56 AM
Mzay
Jul 6, 2015 11:03 PM
