Low mount turbo
HEY my fellow turbo lovers i have a question. So ive pretty much got all my kit ready for install but im curious to know since im running a low mount right under the passenger side, right beside the oil pan can i or can i not just run the turbo return line thru the oil drain ??
If you had some pics it would prolly help. You need the bottom of the center section about as high as where the oil pan meets the block caus the oil level is prolly an inch above the low oil level sensor. You need the turbo a lil higher than that so it can drain and free flow.
zblee
63
Jun 10, 2023 01:25 PM
