Low Boost-what do I troubleshoot?
Old May 11, 2006 | 07:13 AM
dewmanshu's Avatar
Moderately Differentiated
Default Low Boost-what do I troubleshoot?
A few months ago I floored it..."POP" was the noise under the hood. Nothing like a "BOOM", just "POP". From that day I went from a WOT 7.8#'s of boost to now a 4#max then settle to 3.5#'s. (I have a 3.0 Pulley) I didn't troubleshoot then, waaaaaay to caught in other stuff, but now it's on my list. Some things to help...
1) electronic boost gauge. reads normal vacuum, except sometimes...sometimes on the highway at high speeds and no throttle it will go past -30. Which is --- on the gauge. hmmmmm... I have not tried a mechanical gauge yet, but FWW I used to run out of injectors at WOT. I don't anymore, and it just doesn't seem that fast anymore (SOMP gauge).
2) there is some belt dust gathering up. I could use a 110.5 belt, I only have a 111.5 now.
3) I have not inspected the crank pulley/bolt besides with my hand, and it is at least not loose with my hand. But if that was the prob, would it be that consistent? Shouldn't it be fine sometimes, not others, mixed boost levels?
4) I can't find any vacuum leaks. Just physical inspection and short garden hose to the ear test.
5) Bypass seems fine. I really don't how to test that. Moves with my hand.
6) Manifold bolts at 90 in-lbs.
Any other directions? I know I should still do a mechanical gauge. I am working on that, any other avenues or "oooh it could be this" suggestions.
Thanks!
Dewey
Old May 11, 2006 | 11:44 AM
BlownChevy's Avatar
blownerator
25 Year Member
I would highly suggest removing the supercharger and inspecting the intake gaskets....If those look good, then its time to send that sucker in to Magnuson.
Old May 11, 2006 | 01:59 PM
dewmanshu's Avatar
ugh. 30K miles on it.
Old May 11, 2006 | 02:01 PM
BlownChevy's Avatar
blownerator
25 Year Member
I can tell you this....the "POP" could not have been good.
Old May 11, 2006 | 02:30 PM
dewmanshu's Avatar
Yeh I know, dammitt! I so don't wanna pull her off. again... as I said before, UGH.
Old May 11, 2006 | 04:34 PM
dewmanshu's Avatar
on the way home tody...65* out, raining...I could get 5.8#'s Now it seems inconsistent.
Old May 14, 2006 | 09:22 PM
Holty's Avatar
Notorious BIG
dewey, any update on this issue?
Old May 15, 2006 | 07:25 AM
dewmanshu's Avatar
notta. Nothing. With my "pop" I should probably pull the radix and make sure the inatke gaskets are right (i'd replace any way). With my time restraints it's juts not an option right now. Obviously if it breaks down, I'll be forced to make time. Again...ugh.
Hell, I actually don't want to pull the radix cuz it will open up a hornet'ss nest of mod's I'd like to do. LOL
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
carid
Oct 1, 2015 09:22 AM
redbird555
Sep 30, 2015 09:28 AM
Rockrz
Sep 29, 2015 09:07 AM
trevorh1
Sep 27, 2015 08:47 PM
