low boost-high boost question
Old Dec 19, 2007 | 08:55 PM
stock48's Avatar
9 Second Truck Club
Originally Posted by trever1t
You wont need to worry, who/what is going to be a threat to you? Seriously, after riding in Rick's truck, a measley 5.3 with 14lbs i am convinced you will need full time all-wheel drive.
More like AWD with slicks on all 4 corners. 427 with 20 PSI of boost
Old Dec 19, 2007 | 09:17 PM
04Denali's Avatar
Thanks for all your replies,
I am getting excited to get my truck back.
Mark
Old Dec 19, 2007 | 09:20 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I bet!
You still going to Synergy Saturday?
If so I'll see you there.
Old Dec 19, 2007 | 09:30 PM
04Denali's Avatar
I bet!
yes I am, but I don't know what time. I signed the overtime list for Sat day shift and Grave Yard. If I get called in for day shift I will get off work at 1:30 and be there by 3:00. if I don't get called in I will be there by 10:00 am
Old Dec 26, 2007 | 05:59 AM
Spoolin's Avatar
GFYS and STFU
Lol, I doubt you'll be losing to anyone even at low boost but in case you are you can just flip the switch while your at WOT but warning...It's a VIOLENT JERK and would not recommend doing it often.
If your racing on low boost and losing I would suggest lose the race, get off the throttle flip to high boost and ask for another race.
I went from Low to High once when racing but this was at much lower boost levels compared to what your thinking about doing so just amplify what it would do with your set up as compared to mine.
I was on the freeway doing about 70 when a Camaro SS flies by me doing maybe 100. I stomp on it and catch up to him. At the time I'm on low boost which is 3psi for me and with my stock 5.3L. He see's me pass him and he get's on it and slowly starts walking me at which point I realize I'm still on low boost . So I reach up and put it into High boost while I'm at WOT going about 105mph at like 4500 rpm.
I heard my waste gate SLAM shut, my boost spikes to about 11-12psi before the wastegate can settle it back down to 8psi, which is where I had it set at in High. My truck KICKS forward pretty hard and the back end squats down for a hard second before leveling out again and the next time I look down I'm doing 144mph.
I don't know if it's bad for the engine but I didn't do it again after that. Something about making a truck squat while already under load doing 105mph makes me think it's not good on the rear end gears or the tranny. Felt like a shot of Torque running down through a drivetrain that's already under load, which isn't the best for it IMO.
You gotta realize the time it takes for the turbo to hit full boost is instantaneous because the exhaust flow is there already for the turbine, it's just being re-routed to bypass the turbo. There's no build up of exhaust flow and boost to be had as you woud would typically see when running up through the RPM's so the power is not gonna come on gradual as you might think. The time it takes for a turbo to get from 90K rpm's to 120K given full exhaust flow is timed in the milliseconds.
So it's kinda up to you, I'm sure someone who knows more could probably give you a better idea about wether it's bad or not but with the power levels you'll be seing I'd be wary about doing it. That's the equivalent of a 400 HP shot of Nitrous being handled by your drivetrain.
Old Dec 26, 2007 | 06:05 AM
Spoolin's Avatar
GFYS and STFU
After thinking about it...If someone could remind me next time I get on a dyno I'd like to try it out on a dyno to see what the power curve would look like.
Old Dec 26, 2007 | 09:30 AM
did i read that right? you're gonna be running 25lbs boost on a twin turbo 438?
what are the turbos?
Old Dec 26, 2007 | 10:48 AM
Spoolin's Avatar
GFYS and STFU
I was gonna get you the link to his thread and then noticed you already saw it...and in the process was wondering if it was a good idea to show it too you, considering all you've been through!! Lol
Old Dec 26, 2007 | 11:59 AM
04Denali's Avatar
Really we have no idea what boost levels we are going to be at. We will go as high as we can on race fuel and a **** load of meth for the Dyno pulls and than back it down to a nice strong SAFE street tune. We will find out real soon.
Mark
Old Dec 27, 2007 | 02:32 PM
Hawk179's Avatar
Everyone who starts with 20psi in their mind, ends up with about 14psi. Its common practice, once the realization of how fast that **** is, you will tone it back.
RIck
