love the pro
Old Nov 9, 2009 | 04:43 PM
  #41
MFIC's Avatar
Most iv seen from a f1r is 990ish on a lsx427 in a vett at about 18psi. Hellbent10s is making 800 + on a stock 6.0 with c16 and a turbo. I would say try it i'm sure it would be fun for awhile.
Old Nov 9, 2009 | 05:46 PM
  #42
1989k1500's Avatar
Dave's"Dadkins" GTO that TJ helped build and tunes makes 825rwhp with a stock LQ9, S372 front mount and 110.
And Blackburns truck is making quite a bit with a BEI 370 and tc78 tuned by TJ.
Old Nov 9, 2009 | 06:00 PM
  #43
rgvsierra's Avatar
how about a GTO F1R
https://ls1tech.com/forums/dynamomet...7-f1r-gto.html
Old Nov 10, 2009 | 01:14 PM
  #44
WJ MARK's Avatar
It's all about set up stall tis huge like u said and spinning them high 6500rpm for most I'm shifting at 7000rpm. I also helped steves awd tbss run 11.5 up here at only 10psi for the fastest awd tbss. We should have that silvy SS running 11.9 at sea level on a p1 it will be maxed out. It pisses me off I have a built motor and f1r at 14psi and I can only keep up with a stock bottom end tbss with a d1. But I had a hand on his build and tuned it..... One of these days I'll turn it up and show him some tail lights
your right on the stall, one of the main reason I ditched the procharger. I tow a big enclosed trailer with mine and the higher stall wasn't the best for my tranny and towing. got the turbo, a built tranny and went back to a stock stall converter. The bigger the stall the better the prochargers work!
Old Nov 10, 2009 | 02:42 PM
  #45
Bad_Apple's Avatar
That GTO is sickkkk 9:19 @ 152 hahaa
Old Dec 25, 2009 | 08:37 PM
  #46
stock48's Avatar
9 Second Truck Club
I live at 4900 ft with 8000ft + DA's in the summer I can run mid 11 all day up here. we pick up 2-3 psi at sea level so I do know what it can do. I started with a p1 now I have a f1r due to the high ele here. You can always go bigger with a procharger. So what size blower ran out of breath for u.
Yeah the elevation makes alot more of a difference than most think. I ran 10.65 at 4900' elv 7800' Da with 16psi and 22* of timing. Went down to 600' elv at 2800' Da and went 10.3 on just 14psi, and 19* of timing along with another 100LBS of weight in the truck.
Old Mar 20, 2010 | 09:09 PM
  #47
Most Hated's Avatar
https://www.performancetrucks.net/fo...52#post4420152
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
someotherguy
Oct 5, 2015 12:49 PM
