Looking for 2014 CNC stainless header flanges for turbo kit
I'm looking to buy some cnc stainless header flanges to build a turbo kit on my 2014 GMC 5.3 DI. If anyone knows where I could get both header flanges and a T4 turbo flange, would really appreciate it. Thanks in advance. Post up please.
There are a few out there. I had these saved in my favorites for some reason.
There is also a set that is CNCed with a step machined into it so the header tubes fit inside the flange and not flush mounted. I'm trying to find them now.
Cast Header Flanges
found some
http://www.cbrperformanceproducts.co...s1hfss.500.htm
http://www.turbo-flanges.com/product...products_id=36
Cast Header Flanges
found some
if your building turbo manifolds, i strongly recommend running 1/2" Mild flanges for both the head and the turbo. They will get a little surface rust but you can always coat just the flange if you're running SS primaries.
SS will warp extremely easy. You'll need a aluminum jig or a spare head to bolt them down while you're welding with either flange.
Acestainless.com, treadstoneperformance.com, atpturbo.com and the turboflanges.com link posted before are good sources.
You can get Vibrant flanges from summit. they have stainless and Mild flanges. reference their website for part numbers at vibrantperformance.com
Choda
Jan 22, 2026 02:03 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
