Log style turbo exhaust manifolds?
Old Mar 21, 2009 | 08:35 AM
  #31
Originally Posted by kbracing96
WOW! 5000rwhp!
I ran, simen dekas(sp) 60's on my 4.8 (actualy about 70's at our fp) and didn't have any problems tuning for them or with dd performance. They aren't not plug and play, you have to space the fuel rails up 5/8" and change the injectors pigtails to the car style.
Man - nothing gets by you! You would need some 300's to get 5000rwhp and A LOT more turbossss!
Old Mar 21, 2009 | 08:45 AM
  #32
kbracing96's Avatar
Originally Posted by 53RUSSELL
Kyle can you still get the pigtails that connect to stock ones and convert them to car style so you don't have to splice into the wire harness?
You would have to talk to whipple496. He made a couple sets and I got one of them, don't know if he has any more or not.
Old Mar 21, 2009 | 10:33 AM
  #33
53RUSSELL's Avatar
Thanks kyle
Old Mar 27, 2009 | 07:10 AM
  #34
This is what I build, have sold many of them. It's secd 40 steel pipe and weldels. Holds up quite well.
Secd 10 is .120 wall
Secd 40 is .203 wall
Is there ant reason that 3" instead od 2 1/2 for the main log piece wouldn't work? If not what is the effect of the larger pipe? Thanks
Old Mar 27, 2009 | 08:46 AM
  #35
kbracing96's Avatar
I don't think it would make any differences. Pipe is 2 1/2" on the ID, so this manifold is about 3" od.
Old Mar 27, 2009 | 08:58 AM
  #36
Appreciate it - another question - why do you split the header flange in the middle?
Old Mar 27, 2009 | 01:52 PM
  #37
kbracing96's Avatar
For heat expansion and contraction. Probable not as important with the steel manifold, but better with SS which expands and contracts a lot more then steel. If it's cut there, it can move easier and lessens the chances of cracking.
Old Mar 27, 2009 | 03:17 PM
  #38
Thanks - that's probably a good thing to do then. Also, where do you put your wastegate with your style of manifold? The reason I ask is because I found a slick 3" by 1 1/2" tee that I could use in the center of the log. Will that work for the wastegate?
Old Mar 27, 2009 | 06:23 PM
  #39
kbracing96's Avatar
I put the WG in the cross over between the two manifolds. Some people don't like it there, but it works and never had any issue with them.
Old Mar 29, 2009 | 04:44 PM
  #40
I need to keep the WG away from the bottom because this is going into a 4x4 - I assume then it will be OK to put it in the log.
greedygenius
Sep 3, 2015 06:51 AM
Ls3silverado
Jul 31, 2015 04:22 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
GMCtrk
Jul 17, 2015 06:39 PM
