Lbs of boost with stock Roush pulley on 5.3?
Old 01-28-2013, 04:19 PM
travieso's Avatar
im making about 7 Pounds of boost on my Cammed, LT, No Cats, and Catback Exhaust 5.3.. 3.1 Pulley
Old 01-28-2013, 05:34 PM
11 sec. Truck Mod
TIM Z's Avatar
Originally Posted by BlewSilverado
I realize boost is just a measure of resistance. The interesting thing to me is the 3 different results on bone stock trucks ranging from 6lbs (from a pm I received not the 5.3 with a ls9 cam) one with 8lbs and the last with 9.5. The only other variable I could think of is altitude or maybe different heads from the different year models? When you get into mods such as airbox, headers, cam, TB, then of course that changes everything.
This is my third supercharged LS vehicle so I have a little experience with mods and the effect of mods on a supercharged vehicle. I am trying to predict a base line of what to expect. If I put the tvs on and end up with 6lbs I probably wont be happy but on the flip side if I throw a 10% od balancer on and am at 12lbs or more I have probably pushed the envelope too far.
Thanks for all that have given your results and input.
Your not gonna get 12 lbs with a stock pulley and OD balancer .
Old 01-31-2013, 07:20 PM
Come Get Some!!
Ford_Assassin's Avatar
I have a Roush TVS 1900 on my 4.8, which until recently I thought was a 5.3, until I hooked up a boost gauge and its making 11 psi at WOT/6300 RPM. I put a scope down a spark plug hole and guess what? I have a 4.8 (flat top pistons in a 2001 = 4.8).
Still made 430/440 HP/TQ to the wheels in 100 degree heat.
Old 02-01-2013, 12:20 PM
BlewSilverado's Avatar
Good numbers for the lil 4.8 with a 4l80. You must have been thinking ahead and tapped the intake so you could run a boost gauge.
Old 02-01-2013, 01:31 PM
Come Get Some!!
Correct. I drilled and tapped two holes on the rear of the lower blower manifold (aft of the intercooler) prior to installation. One was just an 1/8" NPT that I Tee'd off for the Hobbs switch for the meth/water injection trigger and for the future boost gauge. The other hole was 3/8" NPT for the IAT sensor since I knew I was going with Speed Density for the tuning.
Even in 100+ degree weather the IAT is only 10-20 degrees above outside air temps @ WOT @ 11 psi.
Old 02-02-2013, 08:43 AM
bud8fan's Avatar
yea these 1900 are ery effecient...mine runs cool as well
TAPyvehc93
07-23-2017 10:54 PM
D1SCSS
01-25-2016 10:14 PM
Choda
07-21-2015 03:47 PM
blownss27
07-20-2015 08:59 AM
kdw8888
07-09-2015 10:52 PM
Quick Reply: Lbs of boost with stock Roush pulley on 5.3?
