Lbs of boost with stock Roush pulley on 5.3?
I realize boost is just a measure of resistance. The interesting thing to me is the 3 different results on bone stock trucks ranging from 6lbs (from a pm I received not the 5.3 with a ls9 cam) one with 8lbs and the last with 9.5. The only other variable I could think of is altitude or maybe different heads from the different year models? When you get into mods such as airbox, headers, cam, TB, then of course that changes everything.
This is my third supercharged LS vehicle so I have a little experience with mods and the effect of mods on a supercharged vehicle. I am trying to predict a base line of what to expect. If I put the tvs on and end up with 6lbs I probably wont be happy but on the flip side if I throw a 10% od balancer on and am at 12lbs or more I have probably pushed the envelope too far.
Thanks for all that have given your results and input.
I have a Roush TVS 1900 on my 4.8, which until recently I thought was a 5.3, until I hooked up a boost gauge and its making 11 psi at WOT/6300 RPM. I put a scope down a spark plug hole and guess what? I have a 4.8 (flat top pistons in a 2001 = 4.8).
Still made 430/440 HP/TQ to the wheels in 100 degree heat.
Correct. I drilled and tapped two holes on the rear of the lower blower manifold (aft of the intercooler) prior to installation. One was just an 1/8" NPT that I Tee'd off for the Hobbs switch for the meth/water injection trigger and for the future boost gauge. The other hole was 3/8" NPT for the IAT sensor since I knew I was going with Speed Density for the tuning.
Even in 100+ degree weather the IAT is only 10-20 degrees above outside air temps @ WOT @ 11 psi.
Choda
Jan 22, 2026 02:03 PM
D1SCSS
Jan 25, 2016 10:14 PM
