last shot at a turbo suggestion :/
Old Aug 2, 2010 | 11:41 PM
  #31
SincalT/A's Avatar
Originally Posted by tarinitup
Now that my set-up is in a single cab my max boost droped 5 psi due to not loading turbo enough. 4.10s were nice in the heavy extended cab but too violent on the regular cab. Burns tires at 1/4 throttle. Thinking of 342 or 373.
Why not go with a bigger or sticky tire?
Old Aug 3, 2010 | 12:09 AM
  #32
smokeshow's Avatar
Mod with training wheels
This is damn good info, keep it coming.
Old Aug 3, 2010 | 01:21 AM
  #33
Daryn's Avatar
Formerly darynC-10/23/10
well guys ill know if the 3.42's are a good decision when i get the truck back on the rd. if it feels like they are to long ill switch to 3.73's. the gear to speed chart is sayin i can do 60~ in first and 100~ in second
Old Aug 3, 2010 | 04:44 AM
  #34
Quik's Avatar
5 year bitches!
Didnt you change parts of the build as well? im not buying swapping chassis's made that much of a difference
Old Aug 3, 2010 | 03:56 PM
  #35
TURBHOE's Avatar
I'm with quick on this one. I don't see how the same exact setup looses boost by droping 500lbs when you still probably wiegh 4000 at least.
Old Aug 3, 2010 | 06:24 PM
  #36
tarinitup's Avatar
9 Second Truck Club
Changes were stock to patriot stage 3 heads, 90mm to stock tbody, and tall elbow to car style elbow. Didn't get chance to weigh truck but should be around 4500, I hope.
Old Aug 3, 2010 | 08:42 PM
  #37
Quik's Avatar
5 year bitches!
You lost boost cause you have less restrictions thus more air flow less psi
Old Aug 3, 2010 | 09:09 PM
  #38
TURBHOE's Avatar
Tah dah good heads for the win .... errrr loss in this case.
When I went t my new heads and cam I had to crank the snot out of the bost controler to get my high boost back to 13. And it still won't hit a full 13 like it use to.
Old Aug 3, 2010 | 10:05 PM
  #39
tarinitup's Avatar
9 Second Truck Club
I guess the real question is how do I get my boost back. Already shimmed spring and no difference. It gives higher boost in 1st gear then loses about a pound as it shifts. Really thinking gear swap would fix my problem.
Old Aug 4, 2010 | 04:57 AM
  #40
Quik's Avatar
5 year bitches!
boost is only a measure of restriction. id rather have 15psi at 850rwhp then 15psi at 700rwhp
make mostpower NA then add boost. shimmin the spring doesnt always work, did you try a boost controller?
