last shot at a turbo suggestion :/
#31
#33
Formerly darynC-10/23/10
well guys ill know if the 3.42's are a good decision when i get the truck back on the rd. if it feels like they are to long ill switch to 3.73's. the gear to speed chart is sayin i can do 60~ in first and 100~ in second
#34
Didnt you change parts of the build as well? im not buying swapping chassis's made that much of a difference
#36
Changes were stock to patriot stage 3 heads, 90mm to stock tbody, and tall elbow to car style elbow. Didn't get chance to weigh truck but should be around 4500, I hope.
#38
Tah dah good heads for the win .... errrr loss in this case.
When I went t my new heads and cam I had to crank the snot out of the bost controler to get my high boost back to 13. And it still won't hit a full 13 like it use to.
#39
I guess the real question is how do I get my boost back. Already shimmed spring and no difference. It gives higher boost in 1st gear then loses about a pound as it shifts. Really thinking gear swap would fix my problem.
#40
boost is only a measure of restriction. id rather have 15psi at 850rwhp then 15psi at 700rwhp
make mostpower NA then add boost. shimmin the spring doesnt always work, did you try a boost controller?
