last shot at a turbo suggestion :/
Old Jul 26, 2010 | 04:40 PM
skyhighsami's Avatar
no title here
Originally Posted by 99ta
Why do you say? I would think they would load up the motor and make the turbo spool more, faster...
Ding ding ding ding
Old Jul 26, 2010 | 04:59 PM
tarinitup's Avatar
9 Second Truck Club
It will spool the turbo faster but it doesn't mean that the truck will be faster. I lost time going from 4.10 to 3.73 and now I'm switching back.
Old Jul 26, 2010 | 06:43 PM
no title here
Understand I'm not trying to start a pissing contest I want to learn.....could the better gearing have been masking an incorrect choice in converter or something? I've always seen a lower numerical gearset help load the turbo better causing it to spool much faster than a higher numeric gear set.
Old Jul 26, 2010 | 10:01 PM
Quik's Avatar
5 year bitches!
you cant mod a truck the same as the fbodys. they have slight differences. For a true street truck you need gearing cause we weight over 4k. What good is being in power longer if your truck is slower cause it doesnt have enough forward motion to get off the line?
unless you can leave line with say 700 hp then turn it up on big end why sacifce your setup for lower gearing just to have faster spool?
id rather be at the finish line faster then be in boost longer. converter helps yes, so does transbrake but you still need gear. Doesnt matter if its turbo, super charger, n20 or NA you want to be in your peak power crossing traps.
so if you make peak power at 6k why would you gear your truck so it crosses traps at 4800 ? is it cause you read on the net that lower gearing is better for spooling? id rather be 5800 tru traps and have a better ET. Why do you think you see so many turbo trucks with great mph and shitty ET? gearing is main reason to that
for a 28" tall tire id run 410s, hell i will be 410s and 28" rubber and will be in the hood of 800+ rwhp
Old Jul 26, 2010 | 10:25 PM
tarinitup's Avatar
9 Second Truck Club
I've done just about the apposite of what the "ideal" turbo set-up should be. Going to race with 408 pistons that don't have enough meat to hold power, a 91mm that supposedly is too laggy, 4.10 gears that won't load the turbo, and a 3600 stall that is too loose. I will post whatever times my hooptie runs and maybe a video too.
Old Jul 26, 2010 | 10:37 PM
SincalT/A's Avatar
Hey Darin pm me i got a turbo for you.Its Bens old one 78mm Precision .96 ceramic coated hot side.3" v-band on the hotside.You can pm Ben for more info i cant remember the exact specs but it should get you by.I can do a better price then 775 too.
D.
Old Jul 26, 2010 | 10:45 PM
smokeshow's Avatar
Mod with training wheels
I took my truck out to the street legal night, track was a mess and I was on street tires, but figured what the hell. Impossible not to blow the tires off, even at the end of 2nd gear, but my trap speeds were still really high. Think gearing it down to maybe 410s would change that? With the slicks on, though..
Old Jul 26, 2010 | 10:53 PM
SincalT/A's Avatar
Name change FTW "smokeshow" much better.
Old Jul 26, 2010 | 11:36 PM
iamkeniff's Avatar
im not turboed, im not on Nitrous. my truck went from 3:42s to 4:10s i didnt change E.T but picked up MPH/fuel mileage/and it being a TON more fun to drive. plus the 4:10s help get my brick moving like Quik said. Silver-mod-o wanted to go 4:10s in his turboed ecsb if i recall after swapling from 4:10s N/A to 3:73s just saying....those 3:42s MAY help on a high mph roll race but not E.T wise which isnt the whole reason for going to the track?
Old Jul 26, 2010 | 11:57 PM
Daryn's Avatar
Formerly darynC-10/23/10
D.
DAMIT!!!!!!!.... ive already bought the pt74! its on the big brown truck already..
my goals arent " all out" , i want this to be a " safe" dd ..ill be running 7 to 8 psi or whatever futral says for me to run. ive got the 3.42's cause i need something that aint goign to put me at 3000 goin 70 mph on the highway. if need be ill switch to 3.73's but thats as high as i will go.
