Large intercooler for Maggie's. Is there room??
Old Sep 26, 2010 | 09:17 AM
  #181
xx_ED_xx's Avatar
Hmm..
Old Sep 26, 2010 | 09:30 AM
  #182
Doobie's Avatar
I was able to cool my iAT's 7~10* by just adding a second smaller HE in series with the stock maggie HE. How much of a temp. decrease are you expecting from this combination of mods? I'm currently running 20~30* above ambient with this setup and any additional decrease in IAT's can only be beneficial so I'm watching this thread closely.
Old Sep 26, 2010 | 09:48 AM
  #183
TrickTurbo's Avatar
Truck Sponsor
We should be able to do three bars. It's just a drawing tweek and money. LOL
not sure about coatings getting eaten. I know the old estons would but they issue without methanol. The bars allow you to spray down/at the runner.
And let's say you need want more methanol in one cylinder. Just increase that discharge hole slightly.
Methanol bars get drilled different the nitrous and fuel.
Why would the back cylinder see less boost.?
Something to think about?
Old Sep 26, 2010 | 09:56 AM
  #184
TrickTurbo's Avatar
Truck Sponsor
Not sure the ic is 33% more volume and a single pass. By adding the gaskets that will help thermal transfer as well. And our new tank increasing the volume plus the ability to add a huge amount of ice. So it really depends on how hard it's been pushed too.
Old Sep 26, 2010 | 02:41 PM
  #185
TurboJohn6's Avatar
Originally Posted by TrickPerformanceProducts
It was pretty clean. Methanol bars will be added. as per you pm.
More pics to come.
Sounds good....Thanks again Rick!
Old Sep 26, 2010 | 04:06 PM
  #186
3DTIM's Avatar
As soon as I see the Numbers on it I am ready. I would go with the lager tank to.
Old Sep 26, 2010 | 06:17 PM
  #187
SILVERADO11's Avatar
Nice work Rick! wow that Intercooler sure does look alot bigger in your pictures, should work well with your bigger tank and the CTS-V Heat Exchanger. Will one of my next purchase after my trans/converter i have been saving for.
Old Sep 27, 2010 | 05:49 PM
  #188
supersub's Avatar
Everything is looking very Good. I like that spacer! Lol!. It is good that more out of the box thinking has taken place. Others will soon be able to enjoy the success from this. However, making a larger intercooler for the 2300 and then putting spacer in place will still put it on the floor of the lower manifold. I truly believe most of my spacer's gains are from the result of increased plenum volume.IMHO of coarse!
Anyone who gets in on this should see great results!
Here are a few important ones I have found with mine.
1. Increased plenum = Increased velocity.
2. Reduction of heat transfer/Heatsoak.
3. Allowing the fitment of Larger Injector's.
4. Consistant higher boost levels with less IAT's
Nice job!
Pm me I would like to share some info if possible!
Ray
Old Sep 27, 2010 | 06:01 PM
  #189
blownss06's Avatar
What kind of gasket material is it?
Old Sep 27, 2010 | 07:35 PM
  #190
TrickTurbo's Avatar
Truck Sponsor
Thanks, the intercooler fir the 2300 will be slot higher off the deck then the 112-122.
The 112/122 intakes could gain a huge amount by machining the runners out. Over 2" of space. .
Talk to you soon.
Nice job!
Ray
