Kenne Bell 2.8L latest update.
Old Jan 10, 2007 | 08:13 PM
Default Kenne Bell 2.8L latest update.
Well as I started to tune the new blower a couple of minor limitations will need to be fixed soon.
1)Need to upgrade to 90mm throttle body and larger filter. Current 75mm is choking the blower.
2)Belt slip at 12-13 lbs - need to upgrade to 8 rib setup. Can anyone recommend an upgrade kit. (not too expensive?)
3)Loosing boost through bypass valve - need to re plumb to activate on inlet vacuum as opposed to manifold vacuum.
4)I think I can get even lower IATS by venting the bypass valve to atmosphere. That should prevent circulation of hot air. Good for XX degrees? Any suggestions for a check or blowoff valve.
So far the blower has been awesome, the tuning has taken a while, but lots of fun. Thre is no doubt that the blower is capable of 20lbs once I get things dialed in. Currently, the boost comes on at 25% throttle - pretty sick!
I need to fix the above items before going to dyno.
Someone needs to try the 3.3. Whitt1 any news?
Old Jan 10, 2007 | 08:19 PM
moregrip's Avatar
what a rush!
there is not an affordable 8 rib system to my knowledge, but the good news is they are available.
you get any dyno numbers or track times with that thing yet?
Old Jan 10, 2007 | 08:24 PM
CHarris's Avatar
Thanks for the update... good luck with the final adjustments to the system.
I'm starting to think about a big blower again myself. Easier to do on my own in the garage. A turbo would be awesome... but scheduling is too hard for me. I need something I can work on in my own time.
Old Jan 10, 2007 | 08:26 PM
03sierraslt's Avatar
No track times or dyno #s yet, I have been hounding him to get some. haha
Old Jan 10, 2007 | 08:41 PM
Suggestions on kits?
Planning to dyno after I fix
the 90mm TB and
bypass valve issue and
get stock tires.
Old Jan 10, 2007 | 08:43 PM
Being that the twin screws are always making boost I would wonder what happens if you vent the bypass to the atmosphere. I bet it will be noisy all the time. It might sound like a air leak under the hood all the time.
Old Jan 10, 2007 | 08:46 PM
Also if I am not mistaken V if you set the bypass to run off of inlet vacuum it will never close. It will always see vacuum. Or would it, hmm. Now I have to think, damnit its too late to be thinking.
Old Jan 10, 2007 | 09:19 PM
moregrip's Avatar
what a rush!
the 90mm TB and
get stock tires.
ATI makes a nice kit, you'll need some idler pulleys(Metco is a good source for those)
Old Jan 10, 2007 | 09:43 PM
ATI makes a really nice kit,Moregrip put me on to them,I have the complete ATI setup with Super Damper and 100mm Metco idler pulleys.All I need now is to find a 4.25"8rib Whipple pulley to get started with my 3.3 install.Whipple claims a 3.50" is as large as they make in an 8rib,but it would give me about 19 to 20 lbs of boost.
Old Jan 10, 2007 | 10:08 PM
moregrip's Avatar
what a rush!
did you get those belt sizes/part#'s I PM'd you?
