Kenne Bell 2.8L latest update.
Old Jan 10, 2007 | 10:11 PM
The belt sizes will be a great help,thanks grippy.
Old Jan 10, 2007 | 10:36 PM
Originally Posted by moregrip
ATI makes a nice kit, you'll need some idler pulleys(Metco is a good source for those)
That kit looks excellent. Its almost 1K. Liiks like I will have to delay the stroker kit until later. Can't have belt slip.
Thanks
Old Jan 10, 2007 | 10:39 PM
Also if I am not mistaken V if you set the bypass to run off of inlet vacuum it will never close. It will always see vacuum. Or would it, hmm. Now I have to think, damnit its too late to be thinking.
Im going to hook a vacuum gauge to find out. I believe the bypass valve activates at 1-3 inches of vacuum to overcome the diaphragm.
Old Jan 10, 2007 | 11:19 PM
moregrip's Avatar
what a rush!
Thanks
no problem bro, anytime
Old Jan 10, 2007 | 11:20 PM
moregrip's Avatar
what a rush!
Old Jan 10, 2007 | 11:47 PM
2004SSS's Avatar
anyone have a link to the ati kit?
Old Jan 10, 2007 | 11:49 PM
moregrip's Avatar
what a rush!
no links as they are a non sponsor, just google LS1 ATI 8 rib
Old Jan 11, 2007 | 08:08 PM
ATI makes a really nice kit,Moregrip put me on to them,I have the complete ATI setup with Super Damper and 100mm Metco idler pulleys.All I need now is to find a 4.25"8rib Whipple pulley to get started with my 3.3 install.Whipple claims a 3.50" is as large as they make in an 8rib,but it would give me about 19 to 20 lbs of boost.
Cool! What are you planning for TB - 90mm? Are you running a bypass valve or some kind of blowoff valve.
Old Jan 11, 2007 | 08:49 PM
I already have a 90mm throttle body,but I'm looking into a 100mm as soon as it's available.I have a bypass that came with the Starrperformance kit and I located both a 4.0" and a 4.25"pulley.So I'm real close to installing the 3.3 Whipple.
Old Jan 11, 2007 | 08:54 PM
Mr. Sandog's Avatar
Where's the get-er-done smiley?
