keep shredding belts , what have you done to fix this?
Old Nov 8, 2012 | 01:09 AM
  #31
idahoblkss's Avatar
Originally Posted by FarmTruc
I didn't have time to read the entire thread, but might be a good idea to start with this first.
https://www.google.com/#hl=en&sugexp...w=1680&bih=855
yes ive been looking into these and shopping around cheapest i have found was 85 ish shipped so im going to pick one up here shortly for sure to check alignment .
Originally Posted by slowfive0
Another solution and probably the easier one (although not cheaper) would be a brace similar to these:
Our new KMS crank to supercharger support brace... - Yellow Bullet Forums
dude that brace is legit !! i never heard of them and might have to pick one upif i cant get this figured out.
Judging from your times, I would venture to say that you're running more then 5 psi of boost ;-) That said, I can almost guarantee that your brackets are flexing. Any pulley alignment issues will further compound your problem.
You need to check your alignment (preferably with a laser alignment tool) and then brace up your bracket better. I had a Novi 2000 that I was having similar issues and I ended up having a buddy machine up a new bracket out of much thicker then stock billet aluminum. That combined with a brace fixed my issue (throwing cog belts).
It can be a real PIA, but well worth it when you get it right. Hang in there.
Also, when you're looking to brace your blower, picture a straight line that goes through the center of the crank and the center of your blower. Under boost, the blower head is going to try to pull or bend towards the crank (direction of radiator) along that imaginary line. So you will need to try and brace the head unit so that it can't pull in that direction. Sometimes that is easy, sometimes not so much. On my last project (mustang) we braced the blower head to the strut tower but I was using solid motor mounts. If you have regular mounts, you would need to brace to the engine as the engine is going to move around in the engine bay a little under power, etc. Hope that description made sense---lol.
One other thing, if you're having these problems and have run those times, you are probably getting belt slip here and there as the head unit flexes and potentially unloads the belt. The automatic tensioner is obviously going to try and compensate for that movement. How well it does is questionable. If you are losing boost through belt slippage you'll see it on your logs and will have a lot of black dust around your blower. Bottom line, more performance maybe lurking with just this simple fix ;-) Good luck!
yeah totally makes sense and i would of never thought of bracing in straight line of the crank pulley genus ! i have been looking at speedymetals online and have came across some aluminium plate for a decent price thinking of going with 7/8 thick or just go 1 inch thick for my main bracket, my dad has a machinist that he works with allot so i can get this handled pretty quick. weird thing is we didnt see any belt slip in the logs prior to it shredding which is leading me to believe more that its either not alinged 100% or the bracket is flexing till it hops a rib.
Originally Posted by Blown06
Yea, thats the post I was talking about. Good find.
With that mod and the Gates laser alignment tool I was able to keep an 8-rib belt stuck at 23 psi on a d1sc with stock truck brackets.
yeah no slipping was showing up in my logs and it was showing 22.7 psi.
thanks guys for posting your experiences and linking me to some cool stuff i didnt even know existed , im going to try a couple different things and post results .
Old Nov 8, 2012 | 01:13 AM
  #32
idahoblkss's Avatar
and one more thing do you guys think a manual tensioner would be better then a spring loaded one ?
Old Nov 8, 2012 | 01:25 AM
  #33
Mangled03gmc's Avatar
Baltimore Whore
I have heard that a manual tensioner will be more of a issue with boost on a serp set up.. As you load the belt up it will stretch. The manual one will not take up the slack, will lead to the belt to pop off, or even more belt slip..
Old Nov 8, 2012 | 11:21 AM
  #34
idahoblkss's Avatar
i dont know, all of the good after market kits like A&A kits for corvettes and eveything else are all set up with a manual tensioner .
Old Nov 8, 2012 | 12:12 PM
  #35
Baltimore Whore
Post up some links.. Are you saying the other kits for boosted apps use a manual tensioner with a serp set up?
Old Nov 8, 2012 | 01:06 PM
  #36
idahoblkss's Avatar
yeah for supercharged set ups, my buddy has this kit on his vette and its a manual tensioner , scroll down the page there is a pic of the tensioner .... A & A Corvette Performance, Your C5, C6 and Z06 Corvette Supercharger Specialists
Old Nov 8, 2012 | 01:20 PM
  #37
Baltimore Whore
It looks nice. I think katech makes one also. If you get one please post results..
Old Nov 8, 2012 | 03:35 PM
  #38
Revolutionary's Avatar
I will save you a ton of time.. because I went though what your going though 5 years ago when I had the 370 with the D1sc the whole setup that was in my truck is in another guys ss' truck down south now. It's running around 20 psi with a reichard racing 8 rib it's got an innovators west 8 rib conversion I added braces to both the tensioner and the blower bracket itself to keep it stable. YES the bracket flexes the harder you rank on the blower asking for more boost the more flex it gets. I have seen it first hand Shredded even the green gates industrial belts. The 8 rib conversion helped and at 16 psi it's very stable it won't kill the belts nearly as bad as it does when it's twisted up but it still is hard on them.
The solution is to put the blower in a different spot. There are a couple guys doing different things I have a plan in mind exactly how to do it not only keep the head unit stead but be able to twist on it very hard. I just don't have a vehicle or customer willing to pull the trigger on the idea now because it's not cheap.
The tensioner is not your main issue it's the alignment of the drive under load. The blower is heavy and hangs off the side of the accessory brackets making it easier to twist.
Old Nov 8, 2012 | 04:17 PM
  #39
idahoblkss's Avatar
dude good to see your still around , havent seen you post on the forums in a while . but yeah the bracket is defiantly a weak link in this set up . i have even called procharger and they admit that the truck bracket system wasnt meant for high hp use and that they have been getting more and more request for a better system and that they might eventually address the problem and make a beefier bracket system one day .... i highly doubt it but it was cool to hear anyway. how did you set up the system on your old set up? if i were in the vegas area i would love to work with you to get a set up going but 600+ miles away aint going to cut it lol.
Old Nov 8, 2012 | 06:14 PM
  #40
I still have my engines machined 1700 miles away just drive her down get drunk in vegas for a minute fly back and come back in pick her up when shes done..
I am still around but have been a one man show running shop dealing with customers and doing the shop work so it's been hard to come around. I will try to more though!
