KBracing Compound turbo kit doing work!!
Old Oct 29, 2013 | 12:04 PM
  #21
I bet that would be bitchin in a 5.3L 4x4.
Old Oct 31, 2013 | 01:35 PM
  #22
Denali08's Avatar
Originally Posted by vicalma03
We are using 60 and 80mm turbos. So far its been a good learning experience. Theres no way this 4.8 would spin the 80 like its doing if it wasnt for the 60 down low. I can only imagin what this thing is gonna do at 20+psi and a 75 shot down low. Well the only thing I can really imagine is a blown engine ha!! Kyle is helping me install the roll bars next week and we will be back at the strip to see what it will do.
As far as the brakes go. I did not know that. I will lookIinto the drums and see what the issue is then. I already have a 2 step installed so maybe I jave a weak ps pump or just need to flush the old brake fluid out.
How did you wire the 2-step? To a push button or to a switch under the brake pedal?
Old Oct 31, 2013 | 08:02 PM
  #23
vicalma03's Avatar
Its wired to the brake pedal. I have to manualy turn the 2 step off because my pedal doesnt return fast enough. I kind of like it better that way though. I may just rewire it on a push button.
Old Nov 1, 2013 | 02:19 AM
  #24
Denali08's Avatar
Can you post a pic of your switch mounted to the brake pedal? Is it a contact switch like NOS switch?
Is the switch on the ground wire or the +power wire?
I'm thinking to connect my 2-step through a push button or a toggle switch when I install it.
Old Nov 1, 2013 | 05:51 AM
  #25
vicalma03's Avatar
If you hook it up to a tpush button all you need to do is find a switched 12v wire and your good to go.
Choda
Jan 22, 2026 02:03 PM
Rafe19
Oct 18, 2016 12:27 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
71ls2
Jul 20, 2015 11:53 PM
Cowboy17
Jul 9, 2015 08:22 PM
