KB Racing Turbo Hot Pipes kits NOW AVALABLE!!
Old Apr 9, 2008 | 06:49 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by TG02Z71
Sooo uhh, if i get this set up I can do away with the STS return pump?????
Almost forgot, 4x4 compatible??
Yes and yes
Oil drain on a high-mount front turbo is gravity drain.
Crossover clears the front driveshaft and everything just fine Kyle has his kit on his truck and mine, both are 4wd.
Old Apr 9, 2008 | 06:58 PM
kbracing96's Avatar
Looks heavy duty and sexy at the same time!
Nice work KB.
Thanks!
See the front drive shaft in the 5th pic
Old Apr 9, 2008 | 07:50 PM
TurboGibbs's Avatar
Nice simple kit for a good price. Props on using the mild steel over the stainless. As well as the MIG welding. Stainless is over priced and over rated with a turbo system IMO. And who needs pretty TIG welds with 99.9% of the trucks. I haven't seen any trucks on here that were interested in entering into World of Wheels.
Mild steel is much cheaper and more durable with the heat.
Old Apr 9, 2008 | 09:21 PM
vanillagorilla's Avatar
I don't have and driving experience yet with his manifold, but I've been drooling over it for about a month now. Granted I haven't used it, but it's still a testament to Kyle's skill and attention to detail.
I love my manifold!
Old Apr 9, 2008 | 11:21 PM
stock48's Avatar
9 Second Truck Club
Originally Posted by kbracing96
Hey guy's I though I would let you now that I have decided to become a board sponsor and sell my hot pipe kits! Here is what will be included. A base kit will have the cross over pipe made from 16 ga aluminized steel, a Turbo manifold built out of HEAVY schd 40 (3/16 thick) steel pipe and weldels, and a 3" aluminized steel down pipe. This base kit is going to be offered at a introductory price of $1500.
Upgrades to this will be a 3 1/2" aluminized steel down pipes for an additional $100.
Also a Tail, or equivalent waste gate and flanges can be added for an additional $300.
The base kit will not have provisions for a waste gate since there are too many different type and mounting possibility's. The down pipe will terminate just under the body and will need to have connections made to attach it you your tail pipes.
Here is some pictures of pipes I have built and how the system is laid out.
3 1/2 down pipe (cut out and waste gate are not included in the 3 1/2 down pipe or base price)
I will post some pics of the actual kit pipes in a few days
Let me know if you have any question about anything.
Kyle
Looks good! How much different was the setup you built for your Dad's early 70's pickup? Will the same log fit?
Old Apr 9, 2008 | 11:30 PM
kbracing96's Avatar
The log should fit, but I don't think the down pipe would and the cross over wouldn't clear the front drive shaft. The heater box would be in the way. The turbo sits up a lot higher with this manifold. His was the first one I built.
Old Apr 10, 2008 | 12:28 AM
454SuperSport's Avatar
i'm looking forward to some better pics of the kit what kinda clearance does the 3.5" downpipe need as far as lengthening or bending the A/C hoses?
Old Apr 10, 2008 | 12:32 AM
kbracing96's Avatar
The first pic is of the 3 1/2 down pipe. plenty of clearance. The manifold it a little close to the hose in one spot, but we just put a little header wrap on it and it's fine.
Old Apr 10, 2008 | 12:40 AM
few more ?'s, does the price include the v-band connections on the crossover and both ends of the downpipe? what about the flex pipe in the crossover? also, what kinda turbo is it setup for? t4 tangenial?
Old Apr 10, 2008 | 12:42 AM
laynlow77's Avatar
why would you temp me like this?
