KB Racing Turbo Hot Pipes kits NOW AVALABLE!!
Old Apr 10, 2008 | 12:43 AM
  #21
Stoichiometric's Avatar
Originally Posted by laynlow77
why would you temp me like this?
Twincharge!
Old Apr 10, 2008 | 12:57 AM
  #22
kbracing96's Avatar
Originally Posted by 454SuperSport
few more ?'s, does the price include the v-band connections on the crossover and both ends of the downpipe? what about the flex pipe in the crossover? also, what kinda turbo is it setup for? t4 tangenial?
The crossover will have the flex and the v-band connection to the manifold. The down pipe will have the V-band and clamp to the turbo and it is setup or t4 tangential housings with 3" v-band. The bottom of the down pipe will be left open for you to make the final connection to your tail pipes.
Old Apr 10, 2008 | 01:28 AM
  #23
454SuperSport's Avatar
sounds good man, get some good pics up asap, i want to go turbo so bad i can taste it
Old Apr 10, 2008 | 01:45 AM
  #24
Wilde Racing's Avatar
How do I change this text
About flip-en time!! those manifolds look to good to not talk about!
Old Apr 10, 2008 | 05:10 AM
  #25
slowec's Avatar
Sts to front mount parts huh...
Looks awesome, Maybe I need three jobs.
Great job!!!
Old Apr 10, 2008 | 09:59 AM
  #26
thanks to kbracing96 I have a right and a left mainifold on my 72 truck Thanks for the good job Kbracing96 I need to post pic. jim
Old Apr 10, 2008 | 01:03 PM
  #27
kbracing96's Avatar
I think you NEED a kit Dusty Easy STS conversion
Great job!!!
Glad you like them Jim, I want to see how those fit on you truck!!
Old Apr 10, 2008 | 05:02 PM
  #28
TG02Z71's Avatar
So your turbo mounting flange will fit which turbo housings? I currently have the STS base kit turbo but will upgrade to a 67 once I get my 5.7l engine built.
If I buy these I would most likely get them plated or coated, maybe JET HOT or Nickel just to keep corrosion down. Ever heard of turbo hot parts being plated with Nickel and holding up to the heat? I know it's just a replacement for the stock manifold on that side so it should not run any hotter than stocker other than the engine putting out a little more heat/power that is over a stocker.
The only reason I say Nickel plated is it looks better than chrome IMO and is the plating that goes on before chrome in most cases anyway.
Old Apr 10, 2008 | 08:23 PM
  #29
kbracing96's Avatar
Yep these hot parts are just what you need to convert your STS to a front mount. (that's what I did ) They are built for the same turbo housings that is on your STS. I haven't heard of anyone nickel plating exhaust parts personally. I don't know what it would do once it gets hot. I know chrome turns purple.
Old Apr 10, 2008 | 09:05 PM
  #30
ZO6Ted's Avatar
Sweet! I am making a mental note.
