KB Racing Turbo Hot Pipes kits NOW AVALABLE!!
Old Apr 9, 2008 | 02:59 PM
kbracing96's Avatar
Default KB Racing Turbo Hot Pipes kits NOW AVALABLE!!
Hey guy's I though I would let you now that I have decided to become a board sponsor and sell my hot pipe kits! Here is what will be included. A base kit will have the cross over pipe made from 16 ga aluminized steel, a Turbo manifold built out of HEAVY schd 40 (3/16 thick) steel pipe and weldels, and a 3" aluminized steel down pipe. This base kit is going to be offered at a introductory price of $1500.
Upgrades to this will be a 3 1/2" aluminized steel down pipes for an additional $100.
Also a Tial, or equivalent waste gate and flanges can be added for an additional $300.
The base kit will not have provisions for a waste gate since there are too many different type and mounting possibility's. The down pipe will terminate just under the body and will need to have connections made to attach it you your tail pipes.
Here is some pictures of pipes I have built and how the system is laid out.
3 1/2 down pipe (cut out and waste gate are not included in the 3 1/2 down pipe or base price)
I will post some pics of the actual kit pipes in a few days
Let me know if you have any question about anything.
Kyle
Old Apr 9, 2008 | 03:04 PM
BlackGMC's Avatar
Resident Retard
Freaking awesome and great price BTW!!!
Old Apr 9, 2008 | 03:07 PM
ZZebes's Avatar
Bump For a GREAT PRICE and an amazing set of hotpipes, i have a KB Racing Manifold on my truck and it's immaculate
Old Apr 9, 2008 | 03:10 PM
fastnblu's Avatar
KB nice work. Newbie to turbo stuff. Curious, why 2pc. flange on manifold? Either that's how they're manfactured or does a turbo heat them up to the point where this is the best way to avoid leaks. Q2:What about stainless, is it more of a $ issue or durability?
Old Apr 9, 2008 | 03:23 PM
kbracing96's Avatar
I cut the flanges in the middle after I finish building them to allow for expansion to help keep it sealed to the head then it get hot. The bolt holes are also enlarged so it can "move" a little as he heats and cools. Helps keep things from cracking.
I don't have the means to build anything out of stainless right now . Steel also has less of an expansion rate then ss as it gets hot, so it less likely to crack.
Old Apr 9, 2008 | 04:15 PM
WJ MARK's Avatar
are those all mig welded? looks pretty good for a mig job!
Old Apr 9, 2008 | 04:23 PM
thunder550's Avatar
High on diesel fumes
I had Kyle build me a set of hot pipes (some of the pics above are from my setup) and I am extremely happy with how it all came out. I'm happy to see that all of you now have access to these kits as well
Old Apr 9, 2008 | 04:59 PM
Stoichiometric's Avatar
Kyle has done an excellent job with these hot pipes. The two piece flange, enlarged holes, and flex sections are evidence of a well designed kit. Great job and price
Old Apr 9, 2008 | 05:06 PM
thunderwagen's Avatar
It looks real god Kyle. I really like how you integrated the cut out into the down pipe.
Old Apr 9, 2008 | 06:40 PM
TG02Z71's Avatar
Looks heavy duty and sexy at the same time!
Nice work KB.
Sooo uhh, if i get this set up I can do away with the STS return pump?????
Almost forgot, 4x4 compatible??
