KB Racing FULL Intercooled kit!!
Old Jan 13, 2009 | 08:17 PM
  #111
kbracing96's Avatar
Originally Posted by chevrolade
Man thats nice,t76?what pump/injectors do u use on your t76 truck turbo kit?
That was with the T70, .68 A/r exhaust and 43lbs injectors and Walbro intank. Now I have the T76 and 60 lbs injectors.
Old Jan 16, 2009 | 10:59 AM
  #112
ecmoney's Avatar
Hey i have a question. Say you have long tubes, is your kit fit for the stock headers or do you have a setup for the longtubes? or would that just be something the installer would take care of?
Old Jan 16, 2009 | 11:20 AM
  #113
kbracing96's Avatar
My setup uses the stock manifold on the drivers side and my custom manifold on the passanger side. Headers are not needed or help full with a turbo setup.
Old Jan 16, 2009 | 11:33 AM
  #114
Coban's Avatar
Originally Posted by kbracing96
....Headers are not needed or helpful with a turbo setup.
I think thats one unique thing about Kyle's kit. His thick pipe manifold seems like it will keep heat in better than the tube ones. I have no data to prove it though.
Just for example though, STS guys have proven that the tubing (like in headers) hurts their turbo spool time. They always keep the stock manifolds.
(Made a correction in the quote too Kyle)
Old Jan 16, 2009 | 01:07 PM
  #115
ALL ULL C's Avatar
PM(s) sent Kyle...
Old Jan 19, 2009 | 01:42 PM
  #116
ecmoney's Avatar
I see I see. thanks alot for all the input. this is prob one of the most informative threads i have read yet. at least for someone that lacks turbo experiance like myself. I will start saving so i can give Kb a call soon
Old Jan 19, 2009 | 07:12 PM
  #117
LEADING EDGE PERFORMANCE's Avatar
FormerVendor
Looks good!!
Old Jan 23, 2009 | 01:20 PM
  #118
tank454's Avatar
Two questions. Will this kit work with a Vortec 454? And if so, will the intercooler fit behind the grille of a 1996 suburban?
Old Jan 23, 2009 | 03:29 PM
  #119
WJ MARK's Avatar
The answer to your question is NO and probably Not.
Old Jan 23, 2009 | 03:37 PM
  #120
tank454's Avatar
If that is the case, does trick have anything that would fit a big block chevy? or are there only kits available for small blocks?
