Katech EXTREME D-I Fuel Pump System
Old Sep 13, 2019 | 09:17 AM
JADSCOOP's Avatar
Default Katech EXTREME D-I Fuel Pump System
Help me understand this system? Could I add this to my existing Supercharged L86? Replace the 4.00 pulley with a 3.00 pulley and that would increase horsepower? I would not have to change the camshaft or any other internal parts?
YOUTUBE : Katech Xtreme D-I Fuel System
Old Sep 13, 2019 | 10:41 AM
Jonblarc7's Avatar
Holly crap for 4,500 buck I would swap cams. I don't think I would want to push AFM lifters to that level. I'm no expert though.
Old Sep 13, 2019 | 10:44 AM
JADSCOOP's Avatar
I agree it would be cheaper and safer to replace the cam and lifters.
But is that what they are saying this fuel system will do?
Old Sep 13, 2019 | 08:39 PM
randeez's Avatar
i think you would still need to upgrade injectors and probably in tank (low side) pump
Old Sep 18, 2019 | 10:34 AM
EarlH's Avatar
This is just the high side pump... If you are at the hp level to consider using this pump, you will have already upgraded low side fuel pump(Range: $1,000/inline -$3,000/fore in-tank triple) and injectors (Range: $400/lt4's, $3,000+ for LT4+10%).
Currently going thru fuel system upgrade on Turbo Gen V truck (switch from Whipple) as we speak, after having done same on C7 Z06. I decided to go port injection route. Parts list:
- LT4 Injectors
- LT4 HPFP
- Crawford Racing 1st gen Port Injection Kit (uses stock E38 ecm as secondary controller)
- Custom Magnafuel Inline Fuel Pump
- Flex Fuel Capability (pending)
Total Spent (no incl intake manifold): ~ $3,200
Built system to do 800-900 comfortably
scooter k
Oct 10, 2009 02:26 AM
moregrip
Jan 15, 2007 02:12 PM
Blown06
Sep 14, 2006 09:44 AM
-NewLegacy-
Feb 6, 2006 10:03 AM
