Just got the Maggie done
Old Mar 26, 2010 | 10:12 PM
  #61
3DTIM's Avatar
Put my finger over the hole for the IAC and can bring the idle down and even kill the motor. All the wires going to the PCM are stock and have made sure they were good all checked out good.
Old Mar 26, 2010 | 10:31 PM
  #62
DrX's Avatar
DrX
Just tossing out long distance, blind troubleshooting ideas.
I am assuming that it ran the same with the old IAC motor?
So you were running MAFless if you had the intake tube off the TB. That should have set a MAF fail code?
Is the Maggie bypass actuator installed properly and connected to vacuum?
Old Mar 27, 2010 | 08:55 AM
  #63
3DTIM's Avatar
I am assuming that it ran the same with the old IAC motor? : Yes that is way I put a new one on.
So you were running MAFless if you had the intake tube off the TB. That should have set a MAF fail code? : The Only code we are getting now is the crack relearn.
Is the Maggie bypass actuator installed properly and connected to vacuum? : Yes it is own the way it was set to me and yes it is connected to vacuum.
Old Mar 27, 2010 | 10:13 AM
  #64
DrX's Avatar
DrX
You ran the BLK not the BLK/WHT wire to the IAT sensor, correct?
The lever arm on the bypass actuator shaft has a number stamped on it that should match the actuator mounting position. There are R and L versions of each.
Attached Thumbnails Just got the Maggie done-maggie-bypass-actuator-positions.jpg
Old Mar 27, 2010 | 06:45 PM
  #65
3DTIM's Avatar
Yes the black wire. I will look at that and see what it has on it.
Today's fun. Unplugged the IAC and drove it man was it fun ran like a top. Shifted good ran good and everything did fin got it home plugged in the IAC bang right to 2000.
Old Mar 28, 2010 | 11:33 AM
  #66
3DTIM's Avatar
It is at L-3 and that is what the arm has on it.
To be honest I do not think it is the blower. I am thinking IAC or PCM.
Old Mar 28, 2010 | 02:38 PM
  #67
3DTIM's Avatar
I know this is going to sound dumb but what is the purposes of this? Dose it work like a pop off valve like my 6-71.
Old Mar 29, 2010 | 12:14 PM
  #68
3DTIM's Avatar
OK Put on a loner TB today same thing. Unplugged idle is fine plugged in and it jumps to 2000.
Old Mar 29, 2010 | 12:31 PM
  #69
smokeshow's Avatar
Mod with training wheels
keep it unplugged....solved.
Old Mar 29, 2010 | 12:35 PM
  #70
KySilverado's Avatar
On and off valve for boost basically.
