Just got the Maggie done
Old Mar 24, 2010 | 06:51 PM
  #51
3DTIM's Avatar
Thanks a lot I will just keep banging at it. Thinking about buying an HP Tuner so I can do a lot of this myself.
Old Mar 24, 2010 | 07:49 PM
  #52
DrX's Avatar
DrX
Intake gaskets from Magnacharger?
O-ring in fuel pressure regulator block not messed up?
Also, as stated previously:
Is the throttle blade closed tight, and not drilled
Is the IAC motor functioning properly/not seized?
If it is a stock 5.3 and the VE table is still stock, how high does it idle with the MAF unplugged?
Old Mar 24, 2010 | 08:10 PM
  #53
3DTIM's Avatar
Intake gaskets from Magnacharger? : Yes
O-ring in fuel pressure regulator block not messed up? It is good no fuel coming from it. Are you talking about the one in the regulator or the one on the block.
Is the throttle blade closed tight, and not drilled It is tight. But there is a small hole drilled in it.
Is the IAC motor functioning properly/not seized? It is new and seems to be OK.
If it is a stock 5.3 and the VE table is still stock, how high does it idle with the MAF unplugged? : Have not tried that.
Old Mar 25, 2010 | 05:03 PM
  #54
3DTIM's Avatar
Anybody know were I can get my hands on a TB. No one around here sales them here. Just need to test with it.
Old Mar 25, 2010 | 06:37 PM
  #55
DrX's Avatar
DrX
https://www.performancetrucks.net/fo...d+radix+o-ring
Try putting a WTB ad in the classifieds for the TB. I'm sure there are a lot just gathering dust in garages.
Old Mar 26, 2010 | 01:47 PM
  #56
3DTIM's Avatar
Here is were I stand today. With the IAC plugged in 2000rpm unplug it drops to were it should be. Plug in 2000 unplug normal.
Old Mar 26, 2010 | 02:21 PM
  #57
KySilverado's Avatar
Sounds like IAC ( Idle Air Count in tune) needs work. Assuming the IAC valve and wiring to it is okay.
Old Mar 26, 2010 | 03:18 PM
  #58
3DTIM's Avatar
OK wrong on last statement if it is at 1000 it will stay there until I plug it back in and go up from there. And will not go back down until it has cooled off. Unplug it when cool and will idle fine. IAC is new and I cleaned the crap out of TB yesterday so all is clean. Have checked all wires and they are fine.
Old Mar 26, 2010 | 09:36 PM
  #59
3DTIM's Avatar
So No one knows way the IAC is kicking the idle up?
Old Mar 26, 2010 | 09:39 PM
  #60
DrX's Avatar
DrX
Could be a tune or wiring issue, or could just be extra air getting in somewhere else. Did you try plugging the hole in the TB blade?
