Jet-hot vs. HPC coating
High on diesel fumes
Can anyone give me some info or comparisons on these two companies? I have called for pricing on their 2000*+ coatings and HPC is much more expensive than Jet. HPC only coats the outside of the pipes, Jet coats the inside and outside. For the extra price, I would hope that HPC has the better product, but I haven't heard much about them.
It sounds like Jet has a spray on coating, where as HPC dips theirs. IMO coating the inside is more important for the transfer of heat/engery. I would look around at other turbo kits and see what they for thier coatings. I think you'll find that HPC will be more common.
HPC coats inside and out if thats what you want. They did my headers in the high temp black outside only at my request. They coated my downpipe inside and out... with the outside being the high temp black. HPC also coated my charge ducting inside and out with their standard silver. All in all I think I paid $500 for all the coating. The high temp stuff is very expensive but I am happy with the results. When I finally get my exhaust housing in the correct A/R thats been on order forever I will also coat that with HPC high temp black...
Either way you go Jet Hot or HPC are good products... and happen to be local too
Bill
Bill
Bill
Bill
Unfortunately they only do some of the coating here locally. To get their high-temp 2000* coatings I either have to send everything off to Mississippi or Utah.
I got the 1600F high temp black done... in house. I will note the higher temp stuff is done out of state... weird... maybe its a special process that requires expensive equipment(?)...
Bill
Bill
