Its gettin close!
Old Dec 12, 2005 | 10:59 PM
Yellowsierra's Avatar
Originally Posted by SSlow 4.8
will they do anything for my 4.8 lol?
I'll get some pictures of the heads if I dont bolt them down to the new motor by this weekend.
Old Dec 13, 2005 | 08:03 AM
BigTex's Avatar
I'd rune the LS1 heads and put your money toward a set of forged pistons. You coiuld still choose your CR with the valve relief size but end up with a better quench area. That means a better combustion and less detonation.
Old Dec 13, 2005 | 08:25 AM
I've actually already put good pistons in it. I guess i will go ahead and list the parts I have in it.
LS1 block bored to 3.905
Deck milled .006" to get a good surface
Mahle -16cc Forged Pistons
Compstar Connecting Rods
Stock Crank 3.622
Arp Main studs
The LS1 heads
2.02in./1.57ex.
Ported/Polished
Chamber polished
Milled a total .015"
It should be around 66c
8.9-1 CR
317 heads... Stock
Valves Stock
No porting
Stock valve Springs
Has not be milled
Should be 71cc
8.4-1 CR
Old Dec 13, 2005 | 08:39 AM
I think 8.9-1 compression will work out ok. I should still be able to around 15 PSI when I want and around 12 psi on the street.
Old Dec 13, 2005 | 08:49 AM
BigTex's Avatar
I agree, I think 8.4 is too low.
What head gasket are you going to use (diameter and thickness)? How far does your piston extend above the deck?
Old Dec 13, 2005 | 09:02 AM
Im using a cometic head gasket. The diameter is 3.910 and the thickness is .051. The piston pops out .006".
Old Dec 13, 2005 | 11:07 AM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
Im not an expert on this stuff, but i dont see why 8.9 wouldnt be just fine for 12-15 lbs. I know that people w/lq9s in the SSs run 8-9 lbs all of the time and that engine is over 10:1 compression with stock internals. I know my brother was going to run something close to that on his ss with his gt67 kit that he has laying around. Im not sure why he hasnt put it on. Just throw some meth on top of it when your at the track. BTW, besides the combustion chamber size diff, how do the 317 heads flow compared to stock ls1 heads?
Old Dec 13, 2005 | 11:14 AM
white1's Avatar
Originally Posted by Yellowsierra
Does anybody need a good set of 5.7 heads.
Ill swap you , but I cant have my truck down
Old Dec 13, 2005 | 11:18 AM
The 317 heads would flow better if they had bigger valves and where ported. The exhaust side would flow alot beter. Im just ready to get this thing running and the LS1 heads are ready to go where the 317 will need about $350 to fix them right(Bigger valves and machine work) and another 2 weeks down time. It wouldnt matter if I had the money but christmas is coming up so I want have the money till the first of year.
Old Dec 13, 2005 | 01:19 PM
BeefTip's Avatar
hell, through the ls1 heads on there and just keep the 317s. Whenever you get the cash, port and polish the 317s and the valve work and put them on later next year if you are not happy with the ls1 heads. It might be a pain to change that stuff out later, but you might be totally happy with the ls1 heads and you will be on the road in a few days. Im willing those 5.7 heads will do the job just fine. BTW, what type of numbers and times are you shooting for? I dont see why you wouldnt be around 600rwhp if not more at 15lbs.
