Its 3rd down and 1......time to move the chains?
Old Nov 24, 2008 | 10:48 AM
  #41
zippy's Avatar
With you running low boost I'd think that their kit and the 10:1 compression should be a good combo together. My opinion though would be to just go to a turbo kit and up the airflow that way. An 88mm turbo at 8psi would be all the power you'd need and should still spool quickly. 6k+ is too much to me for a head and cam package especially when it's not going to get you any more than you have right now.
Old Nov 24, 2008 | 01:04 PM
  #42
MikeGyver's Avatar
Originally Posted by Whippled 496
.... So you think it would make for more difficulty tuning with the higher CR? Does the higher CR have an impact on boost?
I don't think it will be difficult, but it will have a big difference over the tune you are using now. The effect that is going to affect your tune is cylinder pressure. There will be different places in the rev range where the engine runs more efficiently than with stock heads and cam. You will need to retune to add fuel and/or reduce spark in those areas to avoid detonation. As an example, here is a screenshot of the dip in my high kPa spark table. In this 3D graph, the line closest to you is what my engine uses for almost the whole boost range, rpm is from left to right. I don't know if EFI is the same is the reason for my lengthy explanation of the screenshot.
Old Nov 24, 2008 | 11:16 PM
  #43
Keith's Avatar
If I were to go about re-doing your 8.1L, here's how I would do it.
Raylar cylinder heads and whatever other supporting gear is needed to run them. Then a turbo kit. That's it. Simple and effective. The cylinder heads are going to be key to making big reliable power. Look at the difference in flow that Raylar offers.
If you are concerned about the stock pistons, Ross offers a very good custom piston operation that would take care of those concerns.
Old Nov 25, 2008 | 07:56 AM
  #44
Whippled 496's Avatar
How much could I expect a set of LT's to help out my 8.1L? RWHP gains?
Old Nov 25, 2008 | 08:03 AM
  #45
TurboGibbs's Avatar
A 5.3 with a cam should gain 15-20 rwhp, with good full exhaust that is.
How much difference does Raylar see in their dyno tests? I'd say one of their set ups would be about the same difference as yours blown with LT's.
Ever thought about a cam for yours and the blower?
Old Nov 25, 2008 | 08:31 AM
  #46
zippy's Avatar
After all tuning is done I'd guess 20 and no more than 30. You'd lose some boost, but be able to run more timing. Over all it would be a nice gain. I'm guessing still short of what you want though.
Old Nov 25, 2008 | 09:39 AM
  #47
TurboGibbs's Avatar
How about coupled with a nice blower cam?
Old Nov 25, 2008 | 11:45 AM
  #48
zippy's Avatar
With the right spec's I'd bet 50-60RWHP could be gained with headers and a cam in my opinion. The stock cam in that 8.1L is far from performance related.
Old Nov 25, 2008 | 12:05 PM
  #49
Okay, here is my plan. I can get Just the heads and CAM for a little less. I am thinking of going heads, cam, and LT's....and keeping the blower on. I should be at an rediculously safe 4 or 5lbs of boost after the goodies are on...but I should pick up a few ponies in the long run. 42xRWHP 51x RWTQ now...with heads, cam, LTs, and the whipple.....i should be flirting with 500RWHP and 600rwtq i would think. I think thats what I am gonna do......I think. I plan on starting with the LTs first though.
Old Nov 25, 2008 | 12:16 PM
  #50
1BadAction's Avatar
Registered abuser
why settle for just one whipple?
