Its 3rd down and 1......time to move the chains?
Old Nov 25, 2008 | 10:41 PM
  #51
WJ MARK's Avatar
Originally Posted by Whippled 496
Okay, here is my plan. I can get Just the heads and CAM for a little less. I am thinking of going heads, cam, and LT's....and keeping the blower on. I should be at an rediculously safe 4 or 5lbs of boost after the goodies are on...but I should pick up a few ponies in the long run. 42xRWHP 51x RWTQ now...with heads, cam, LTs, and the whipple.....i should be flirting with 500RWHP and 600rwtq i would think. I think thats what I am gonna do......I think. I plan on starting with the LTs first though.
all the above and a 50 shot.
That way you're still really reliable ,but also have a back up plan at the push of a button
Old Nov 26, 2008 | 10:07 PM
  #52
hog's Avatar
hog
Monitor your injector duty cycle, it will go up as the engine power goes up.
The IDC will increase after the LT header install.
A 496 cube engine with a compressor on it needs a good exhaust. LT headers with a cam could mean some BIG power, regardless of how much boost you are running. Boost numbers are meaningless to power production as it measures restriction, not power.
If you are running 6 psi on a stock 8.1, then add a better intake manifold/heads/cam/headers/exhaust, your boost may plummet, but your power will soar. Its not like the compressor is pushing LESS air when you enhance the flow of parts behind it. Plus the less you work a supercharger, the less power it robs.
I think it would be VERY interesting to see just how much the manifolds, stock pipes and cats are backing up the engine.
You wnat the air to enter and exit and engine with the LEAST amount of restriction, this is esp importantant when you are forcing the air into the engine.
peace
Hog
Old Nov 26, 2008 | 11:13 PM
  #53
Whippled 496's Avatar
peace
Hog
Well, I have the corsa exhaust now. The exhaust alone seemed to pick me up around 3-4 tenths of a second, but i never dyno'd it to see what RWHP gain it gave me. I plan to add the stainless works long tubes in January. They are 2" primaries and 3" collectors. Currently, the two 3" pipes converge into one 3.5" pipe before the corsa muffler...then one single 3.5" pipe exits the passenger side. I am considering true duals when i put the LT's on, but thats gonna cost a bit more considering i would have to pick up some high flow CATs and mufflers and have the exhaust custom bent all the way back. LT's ($750)+ 2 high flow CATS ($600) + Mufflers ($400) + custom mandrel bent 3" pipes ($300) = a hell of a pricey exhaust setup...LOL. Maybe i would be okay with just the LT's and high flow CATs incorporated into the Corsa system i currently have for now?
Either way, i think the heads, cam, intake, and LT's + the Whipple blowing a safe 4 or 5lbs of boost behind it should make for some nice safe gains. I will be starting with the LT's in January and go from there. At this point i think I am sticking with the Whipple just as an "A La Mode" to the Raylar kit. I am trying to get some feed back from them right now on whether the blower cam (at my low boost levels) would be more benificial than the cam that comes with thier kit. I need to find out what specs the cam are that come with thier kit too. I know it sounds so cliche, but at the end of the day...i still want a reliable truck to take camping...LOL. Call me crazy but i think if the truck has been this reliable this long, adding a heads, cam,intake combo shouldn't degrade the reliabilty any.
Old Nov 26, 2008 | 11:40 PM
  #54
WJ MARK's Avatar
how about a 4" d-max exhaust, The MBRP i have was right around 300 bucks.
Old Nov 27, 2008 | 12:29 AM
  #55
TurboGibbs's Avatar
Yeah, he could actually use the rear section at least. I've seen many mandrel stainless factory pipes pulled off them go in the trash at exhaust shops with nothing wrong with them.
Old Nov 27, 2008 | 11:11 AM
  #56
WJ MARK's Avatar
that factory stuff is 3.5. The MBRP I have is all manderal bent.
Old Nov 27, 2008 | 08:49 PM
  #57
So whats the deal with CATs. I guess I cant remove them because of emissions inspections....... but how much difference will high flow cats give me over the ones I have currently? Im gonna look around on Ebay and see what the Dmax exhaust systems are going for too.
Old Nov 27, 2008 | 08:57 PM
  #58
TrickTurbo's Avatar
Truck Sponsor
I have a pair of maganflow hi flows 100.00 a pc. I think hi flows will not effect the power output if they are set up for the HP you are trying to get to. I took mine off when we did the exhaust it was just easier.
Old Nov 27, 2008 | 09:00 PM
  #59
Mangled03gmc's Avatar
Baltimore Whore
You can take them off, still pass.. Unless your place actually looks
John
Old Nov 27, 2008 | 09:01 PM
  #60
Not sure i understand what you mean. Are you saying hi flows are not going to make a real difference over the standard CATs?
John
Thought about that too
