InterCooler Pump Circuit Blowing PCM B Fuse
Old May 16, 2020 | 04:31 PM
therock's Avatar
Default InterCooler Pump Circuit Blowing PCM B Fuse
2005 Silverado Radix installed in 2005.
The Bosch pump recently failed and I found chaffed wiring that caused it. It didn't blow any fuses, I only had noticed high IAT temps and looked into it.
So I install a new one and long story short, it blows the PCM B fuse immediately got a new one.
I direct wired it in a temp fasion to rule out any current wiring issues.
I have it all connected according to the paper, the fuel pump signal wire is the culprit, as soon as I touch it to the 85 terminal it pops the fuse.
I am stumped.
Old May 16, 2020 | 05:46 PM
madmann26's Avatar
Have you direct jumped the pump to see if it even works? It may be seized up or burnt up.
Old May 16, 2020 | 07:22 PM
therock's Avatar
Thanks, I just got it working. Its a new pump replacement so its fine and turns out all relays are not the same. They look the same but if one is a type A and it need a type B there in lies the issue, for me anyways.
The wires installed in 2005 had squirmed out of looming some how taking out the pump and relay. The relays I have around here were the issue. The pin outs and blade layouts all looked and were numbered the same but I guess there is a diode or resistor inside or something. I finally dug out an exact matching Bosch relay and I'm good.
Gorilla4fiddy
Jul 13, 2016 07:12 AM
Burnsdomain
Jun 23, 2016 07:15 PM
00Silv4.8
Jul 21, 2014 11:04 PM
1979rs/z28
Oct 30, 2012 09:39 AM
terravast4
Mar 22, 2009 12:56 PM
