another radix pump question
just got the truck back yesterday from the body shop from a front end collision. I had to replace the heat exchanger and when I got the truck back checked and the pump is not working. if they ran the truck without coolant would it blow a fuse or just burn up the pump? Which fuse is the pump tied into to check that.
The intercooler pump has an inline fuse where it attatched to the underhood electrical center power stud. I think its a 20. Its under the cover. Also if they had the fenders and such off make sure they did not disconnect your tap wire into the fuel pump power wire. Thats the gray wire to power the other side of relay.
GXPJAY
Feb 13, 2022 08:15 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
