intercooler/ heatexchanger
Old Sep 13, 2005 | 02:52 PM
Gmc²'s Avatar
Default intercooler/ heatexchanger
what is the cheapest type(air to water, water to water, air to air)?
what kind do all the turbo cars use?
can you use an intercooler designed for turbos, with a supercharger?
it seems as if fabing your own ic system is the only way to do it.
ohh and what minimum requirements should be met for a low boost aplication through a blower? im talkin like 10LBS or less.
i figure some whipple guys have done it, let me know.
thanx
Old Sep 13, 2005 | 03:36 PM
TG02Z71's Avatar
I would say that air to air would be cheaper.
No heat secondary exchanger (radiator), no pump, no auxilary fan if needed.
check out these links for more info.
http://www.turbocalculator.com/sparco.html
http://www.forcedinductions.com/
http://www.extremeintercoolers.com/
Old Sep 13, 2005 | 04:21 PM
vanillagorilla's Avatar
I don't know if your sidemount can make 10lbs on a 5.3? You can try, but you're right by needing a IC. You might want to look into meth injection first though.
Old Sep 13, 2005 | 08:12 PM
Gmc²'s Avatar
i know i wont go over 10, thats why i made that my cieling. i have looked into meth, and in the long road it will probly be more costly, especially due to my driving habits.
Old Sep 13, 2005 | 08:22 PM
Gmc²'s Avatar
one other question.
is there a difference between intercoolers designed for turbos and sc?
or are they universal for all FI applications?
Old Sep 13, 2005 | 08:31 PM
bud8fan's Avatar
they are all universal...it all depends on what you want to go with...
Old Sep 14, 2005 | 07:56 PM
(Ken)-96GMC K1500 SC's Avatar
thanx
Ford 7.3L turbo diesel intercooler...what I run!
Tech article on build up
Ken
kelsey_canard
Oct 7, 2013 07:53 PM
E140NJ
Jan 9, 2010 11:52 AM
E140NJ
Dec 11, 2009 09:47 PM
E140NJ
Nov 8, 2009 09:08 PM
blackbeast ss
Sep 30, 2009 03:38 PM
