Placement of Regulator for STS boost controller?
Old Sep 14, 2005 | 08:58 PM
TG02Z71's Avatar
Question Placement of Regulator for STS boost controller?
I've seen a couple of your guys set ups in here and I'm going to be finishing installing my 2 stage STS controller tomorrow.
The two I've seen are in the passenger wheel well from what I recall.
The thing is I really want the regulator mounted under my dash but don't know how it will affect the boost with the return hose being so long going back to the wastegate.
I already have a line running from the wastegate to my intake manifold for my boost reference signal, so one line is already under my hood now.
I want to keep the regulator close at hand for adjustment, and be able to keep it clean.
It snows here and the roads are pretty shitty and very salty in winter.
Tell me what you think.
Oh ya, I have the 2 stage Electronic controller.
Thanks guys.
Old Sep 14, 2005 | 10:24 PM
vanillagorilla's Avatar
Couldn't you just tee off of that long run you have, somewhere near the cab. Then just run it in the cab to the regulator/noid, and then back out.
The only downside to this is it won't be as responssive if the tubing were shorter. I bet it'd be hard to notice with the butt dyno though.
Old Sep 14, 2005 | 10:30 PM
TG02Z71's Avatar
I can tee off the existing line that I get my reference signal from but the line that comes out of the regulator has to go back to the side of the wategate that is currently open to air.
I have to look back at the scematic that came with the boost controler to be sure.
I'll copy that stuff for you too when I send the other stuff.
Old Sep 14, 2005 | 10:41 PM
TG02Z71's Avatar
This is Wilde's set up I think.
You can see the hoses comming off the wategate.
The one on the bottom is for boost reference, the one on the far left end of the wategate is part of the boost controller set up.
On the stock kit without a boost controller this port vents to atmosphere.
You can see the line comming out of the intake side of the turbo in this set up is where the stock STS boost reference signal comes from.
I plugged this port and get my reference signal from the intake manifold at the vacum nipple that my boost gauge is also hooked to.
I'll try and find the other pics he posted in the morning, I'm falling asleep here.
Yaaawwwwwnnnnn.
Attached Thumbnails Placement of Regulator for STS boost controller?-pic034sm.jpg
Cool, yeah that's what I was thinking. Either way 1 line needs to be run into and 1 out of the cab. You could get the boost signal off the turbo, then tee off that line. Then run that line into the cab to the reg, then back out to the WG. That would keep it froming having to go all the way to the engine. But then again you'd be getting the boost signal from the turbo and not the manifold.
GXPJAY
Feb 13, 2022 08:15 AM
greedygenius
Sep 3, 2015 06:51 AM
Razor
Aug 16, 2015 11:39 PM
lxcoupe
Jul 15, 2015 10:03 PM
