intercooler/ heatexchanger
what is the cheapest type(air to water, water to water, air to air)?
what kind do all the turbo cars use?
can you use an intercooler designed for turbos, with a supercharger?
it seems as if fabing your own ic system is the only way to do it.
ohh and what minimum requirements should be met for a low boost aplication through a blower? im talkin like 10LBS or less.
i figure some whipple guys have done it, let me know.
thanx
thanx
I would say that air to air would be cheaper.
No heat secondary exchanger (radiator), no pump, no auxilary fan if needed.
check out these links for more info.
http://www.turbocalculator.com/sparco.html
http://www.forcedinductions.com/
http://www.extremeintercoolers.com/
thanx
thanx
Tech article on build up
Ken
kelsey_canard
Oct 7, 2013 07:53 PM
blackbeast ss
Sep 30, 2009 03:38 PM
