Installed wideband today
Old Mar 25, 2008 | 01:25 PM
lpguy's Avatar
Default Installed wideband today
Well finally got exhaust ran yesterday and put in wideband today.... IM pretty sure somethings wrong.. its bouncing all over from 11 to 18...... I have P0171 and p0174 codes im pretty sure i just need to clean off some of the remaining oil residue from the MAF that got on there from my oil problems before. Any suggestions on why why wideband would bounce so much? My wideband is plx SM-AFR with DM-5 gauge
Old Mar 25, 2008 | 02:00 PM
TrickTurbo's Avatar
Truck Sponsor
Vacuum leaks could cause that issue as well. Where did you install the sensor, not real familar with the plx stuff. Some bouncing around is normal at idle or cruising depending on the tune. Or if you lift the truck will show dead lean again depending on the tuning. On the 02 2500HD , it bouced all over the place just depending on what I was doing, etc at WOT then it should have very little movment.
Old Mar 25, 2008 | 02:06 PM
lpguy's Avatar
No vaccum leaks that i can find... i may have a very small exhaust leak where i put the pyro at but its nothing big... sensor is exactl 22" from turbo outlet
Old Mar 25, 2008 | 02:12 PM
Stoichiometric's Avatar
Any exhaust leaks pre sensor can introduce fresh air and cause incorrect reading.
Old Mar 25, 2008 | 02:14 PM
lpguy's Avatar
hopefully i can fix it during my lunch break...
Old Mar 25, 2008 | 06:09 PM
lpguy's Avatar
ok exhaust leak fixed... now when i go wot its goes below 10 and says rich... looks like im gonna try going out to nelson next friday...
Old Mar 25, 2008 | 06:48 PM
FarmTruc's Avatar
Performance Trucks Sponsor
If the maf is dirty from oil, that could definitely cause the lean and rich condition.
Give us a call and set something up, we'll see if we can get rid of the maf all together that way you don't have to worry about it!
see ya,
allen
GXPJAY
Feb 13, 2022 08:15 AM
zblee
Aug 3, 2015 03:45 AM
maxspeed05V
Jul 19, 2015 07:08 PM
slowlsx
Jul 13, 2015 04:18 AM
