Walbro 255 not enough, What next?
Old Mar 24, 2008 | 11:15 PM
La Riddler's Avatar
Default Walbro 255 not enough, What next?
After installing the 60 psi injectors and GT2-3, can't seem to richen it up. Reading 10.8's at 1psi but once I go w/o throttle it leans out to 13's. What should I do to help this pump or what other pump can I go with that wont cost me a bunch.
I'm going to try 2 walbro's in-line and in-tank to see if they work better together. Pls HELP!
Old Mar 24, 2008 | 11:16 PM
TouchOfEvil04's Avatar
Boostapump?
Old Mar 24, 2008 | 11:19 PM
La Riddler's Avatar
Link?
Old Mar 24, 2008 | 11:20 PM
Not sure....i know alot of guys with the maggies run em on the stock pumps to get more fuel from em though.
Old Mar 24, 2008 | 11:24 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
huh?
are you sure the problem isn't in the tune?
trever1t's Avatar
Magnavolt, get it from your Magnuson dealer...
Old Mar 24, 2008 | 11:25 PM
Thats what i was thinking of!!!
Old Mar 24, 2008 | 11:33 PM
Last Call's Avatar
TOTM: January 2007
I think there is definately something wrong here.. I dont know how you could be running out of fuel and going that lean. I would check the tune and fuel system before adding anything else. The charger should also be making a ton more than 4 psi.
What pulley are you running?
Have you checked your fuel pressure under boost?
Old Mar 24, 2008 | 11:37 PM
gao8302's Avatar
Did you tune your pe table correct. I have heard people having a hard time getting the 60lb injectors set up correct. Check your tune again. I was running 8lb and a 216/224 with 42lb injectors just fine, and a walbro 255lph inline pump.
Old Mar 25, 2008 | 12:37 AM
La Riddler's Avatar
I'll re-check with my tuner see if we can figure something out. The 42# injectors were around 102DC @ 6000 rpm with only 4 psi. That's why I decided to go with bigger injectors with the cam swap. So tuning should fix this without using the boost a pump?
