installed i/c truck makes weird noise
Old Nov 22, 2006 | 09:15 AM
Mort's Avatar
Cool
Originally Posted by ogkevin13
thats what i was thinking!! and is it normal i used to boost about 6 pounds now with the i/c am down to about 4??
Do you have the boost reference to your wastegate run from the compressor housing or the intake manifold. Since you have the IC in line you should run the boost ref to your wastegate from the intake manifold and that should cure your drop in boost pressure.
It is possible that the elephant noise you hear when you lift after a WOT run is compressor surge. But keep an eye out behind you just in case....
Old Nov 22, 2006 | 10:22 AM
vanillagorilla's Avatar
right after i let off its sounds like a dam elephant in africa what can it be?
Well if it was just an elephant I might have a solution, but since it's an elephant in Africa, I have no clue.
I'm going to go with compressor surge like the others, but can elaborate more on this noise. Where is it coming from. Behind you? From the IC? The engine?
Old Nov 23, 2006 | 02:53 AM
cpelton's Avatar
compressor surge!
yea i wouldnt mind seein some pics of that side mount IC either
Old Nov 23, 2006 | 01:16 PM
ogkevin13's Avatar
Banned
how do i exactly run the ref. to the wastegate and diagrams?
Old Nov 23, 2006 | 02:36 PM
ogkevin13's Avatar
Banned
sry the pics are crappy it was on my cell. i also took a pick of the alternator i made at my shop.
Attached Thumbnails installed i/c truck makes weird noise-turbo-truck.jpg   installed i/c truck makes weird noise-turbo-truck-2.jpg   installed i/c truck makes weird noise-turbo-truck-3.jpg
Slammed96
Jul 27, 2015 07:22 AM
black6spdz
Jul 16, 2015 01:32 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
Breitling
Jul 6, 2015 06:39 PM
