Innovators 10% overdrive
Old Mar 4, 2017 | 07:59 AM
terravast4's Avatar
Default Innovators 10% overdrive
who is using the innovators set up with a TVS 2300. what blower pulley you using and what boost are you seeing? what is your CI and mods. Thanks
Old Mar 4, 2017 | 10:19 AM
03sierraslt's Avatar
I don't have an innovators setup but I am 10% OD (10% is 10%) LQ4 has a Powerbond 10% and my new motor has an ATI
On my LQ4
224/236 115 cam
Stock motor
102mm TB
2.9" pulley is 15.5psi
Not sure what it will do on the new motor but I have a 2.6" pulley.
Old Mar 4, 2017 | 01:20 PM
terravast4's Avatar
thanks. I'm putting the overdrive on my stroker 383 with trick flow heads with 228/232 cam and 3" blower pulley. thinking i might get around 12 psi
Old Mar 4, 2017 | 01:45 PM
terravast4's Avatar
On my LQ4
224/236 115 cam
Stock motor
102mm TB
what size belt you running? that should work with my 3" pulley you think?
Old Mar 4, 2017 | 06:33 PM
You should easily hit that. On my new motor with TEA 225's and a 230/242 115 cam I plan to hit 17ish on a 370ci
Old Mar 4, 2017 | 08:18 PM
MikeGyver's Avatar
...On my new motor with TEA 225's and a 230/242 115 cam I plan to hit 17ish on a 370ci
15.7 psi
Old Mar 5, 2017 | 03:41 AM
Belt with a 2.9" is a K081088
That's with 90mm idlers.
Old Mar 5, 2017 | 08:54 AM
Atomic's Avatar
I have a gauge for that
I have one but have a 2.3 whipple with a 2.7" pulley and make 14-15psi on a 402.
Old Mar 5, 2017 | 09:13 AM
terravast4's Avatar
thanks man. I'm trying to calculate boost for the 2300 trying to stay close to 12 psi
Old Mar 5, 2017 | 09:14 AM
terravast4's Avatar
i bet that 402 gets on it!!!
