Innovators 10% overdrive
who is using the innovators set up with a TVS 2300. what blower pulley you using and what boost are you seeing? what is your CI and mods. Thanks
I don't have an innovators setup but I am 10% OD (10% is 10%) LQ4 has a Powerbond 10% and my new motor has an ATI
On my LQ4 224/236 115 cam Stock motor 102mm TB 2.9" pulley is 15.5psi Not sure what it will do on the new motor but I have a 2.6" pulley. |
thanks. I'm putting the overdrive on my stroker 383 with trick flow heads with 228/232 cam and 3" blower pulley. thinking i might get around 12 psi
(Post 5400989)
Originally Posted by terravast4
(Post 5400997)
(Post 5400989)
(Post 5401038)
...On my new motor with TEA 225's and a 230/242 115 cam I plan to hit 17ish on a 370ci
Belt with a 2.9" is a K081088
That's with 90mm idlers. |
I have one but have a 2.3 whipple with a 2.7" pulley and make 14-15psi on a 402.
Originally Posted by Atomic
(Post 5401086)
i bet that 402 gets on it!!!
