innercooled front mount!
#22
does mounting it in front of the radiator reduce airflow to the radiator or make it less efficient? Is heat soak an issue from the proximity? I was going to mount mine behind the bumper, but there's not alot of airflow going through the solid front bumper.
#23
mine is low enough to cut out the lower valance(sp) and get a good bit of air flow so i don't have to worry about my tranny cooler getting enough air and not as much heatsoak from the radiator! just fits better down low but if i had it to do over i would go with a a/w in the engine bay with a heat exchanger and all that good stuff! it sure would cut out a bunch of hard pipe routing!
#25
What size is that IC? I have been looking at doing something like that.
Also where did you get the plastic intake tubing?
Looks good! Do you like it?
Are you running a reservoir?
I was looking at some kits on frozenboost.
Nice job.
Nice job.
#27
Its some of the original STS and exhaust pipe mixed, and i spray painted it with some dollar store special rattle can
Love it, along with my new ice box, it works awesome
https://www.performancetrucks.net/fo...d.php?t=442068
Thanks..
#28
I have searched and can't really find any pictures of the cold side piping for a front mount from kbracing, trick, livernois, or any for that matter.....I have found one thread that shows kyles kit mocked up on a stand but nuthing else!
Will you guys with front mounts show me how the cold pipe is routed? I need ideas!
There are several ways to get the job done depending on what you working with, goals, and time line. heres a link and some pics to give you something to work.
air/air
air/water 2000
air/air 07 Avalanche
air/water 07 Avalance
air/water 02 2500
zblee
63
Jun 10, 2023 01:25 PM
