inline pump 4 sts
Old Aug 2, 2006 | 09:30 PM
Mort's Avatar
Cool
I mounted my in-line pump in front of the filter to the bottom edge of the frame rail. I took the filter out of its holder and moved it after the pump. My pump came with barbs and I clamped high pressure fuel line on them. I double clamped the fuel line onto the stock steel line. I left the filttings in the filter cut the steel line and double clamped the fuel line from the pump to it and then from the filter back to the stock fuel line. There was a write up not long ago by blue 01 I think that did the job using proper fittings and looked very good. The only thing I did not like about it was the 180* bends but they may not hurt the flow that much or at least I hope they don't.
Part # to hard plumb wabro in-line
Old Aug 2, 2006 | 09:59 PM
ogkevin13's Avatar
Banned
ok thats sounds pretty easy do u have n e picz ????
Old Aug 3, 2006 | 12:42 PM
Mort's Avatar
Cool
No pics but I will try to take one tonight.
Old Aug 3, 2006 | 02:50 PM
ogkevin13's Avatar
Banned
ok thanks
Old Aug 3, 2006 | 09:52 PM
Mort's Avatar
Cool
It is not a work of art but it seems to work well. Hope it helps.
Old Aug 4, 2006 | 08:08 PM
ogkevin13's Avatar
Banned
looks really good i think am ganna do the same thing u did where do u get the power supply?
Old Aug 5, 2006 | 08:05 AM
Mort's Avatar
Cool
I bought a nice harness made by Racetronix. I put the relay on the firewall and grounded the relay to the ground stud on the firewall. I got 12v power from Stud #2 in the underhood fuse panel with an inline fuse and got the trigger from the grey fuel pump trigger wire in the underhood fuse panel. I ran the power out from the relay down the outside of the frame to the fuel pump and ran a ground wire back from the pump to the ground point on the frame near the front chassis mount on the driver's side.
I hope that the install goes well for you.
Old Aug 5, 2006 | 05:08 PM
ogkevin13's Avatar
Banned
ok sounds easy thanks for ur help whats the trigger switch for i tought it was just ground and power?
Old Aug 5, 2006 | 07:00 PM
Mort's Avatar
Cool
The grey wire is the trigger wire for the fuel pump. You use it to trigger the relay to send power to the inline pump when the stock pump gets power so the two of them are in sync and the online comes on for a couple of seconds to pump up the fuel pressure when you turn on the key and then comes on when you start the truck. Remember the inline fuel pump gets power from the relay and the relay gets power fron the Stud 2 position in the underhood fuse panel. That way the fuel pumps are only on when the egine is running and not when key on engine off (KOEO).
Chavette
Oct 28, 2015 07:33 PM
silver-mod-o
Sep 19, 2015 08:46 PM
chopperloco
Sep 18, 2015 06:44 PM
rednekferlife101
Sep 14, 2015 05:27 PM
InsaneDomestics
Sep 10, 2015 05:32 AM
