inline pump 4 sts
i want to get a walbro inline 255lph does the in tank (stock) stay or have to br removed? also with this set up will i need to run meth? 5.6 sts turno, #44 injectores, 255lph pump, bov,b/c,and fmic?
If the stock in-tank pump is working properly then you can leave it in place. Do you have a fuel pressure guage? If not get one and monitor it when you are WOT and you will know if your fuel pressure is dropping off. You are going to have to tune for the injectors so you may as well get a new tune for all the upgrades at once but you will not be able to run the injectors until you get tuned for them.. You may not need meth but you will need to log some data to make sure that you are not getting any KR at WOT and that your IATs are not too high ( < 160*) which they should not be with the FMIC. With my tune at 10 psi I get 4* to 7* of KR and an equal amount of timing pulled. If I run meth I don't get any KR but you will need to tune for the meth as well if you add it.
Take your time and do it right.
ok sounds good no i dont have a fuel pressure gauge yet. yea that my plans getting everything at once the dyno tunning again. will i still need to log some data after the dyno? also with the b/c how does it work? let say the car is tuned at 12 psi at a high setting what happins when u put it at a low setting? it still uses the same tune as 12 psi right? if it does will it run ok ?
If the truck is re-tuned on a dyno after installing all the new parts then in theory you will not need to log again. I would not leave it there. You are planning to run 12 psi which is quite a lot on a stock block and things can go wrong in a hurry. I would recommend that you log WOT runs on a regular basis so that you get a feeling for how everything is working and learn your system a bit more. It may be time to step up to some logging software at a minimum and probably logging/tuning software as it is the next logical step. A wideband O2 sensor would also be a good investment as logging stock narrow band O2s can be misleading. I just finally went to a wideband O2 myself and it is a bit of an eye opener.
I have the STS b/c and you set it on a manual control for the high setting and on the wastegate spring pressure on the low setting. You control it electonically from a switch in the cab through a solenoid valve identical to the one on the passenger side of the intake manifold. You tune it for 12 psi and it will run the same tune at the lower boost setting. Mine seems to run fine on either setting but I do get KR on the higher boost setting if I don't run meth. I am just starting to tune for the meth now I have the wideband installed. I think you will be fine on the lower setting if you are properly tuned for the high setting.
12 psi =
if you are not careful.
Have fun be careful
12 psi =
if you are not careful.Have fun be careful
Originally Posted by ogkevin13
ok but am not going to run meth (or should i? ) just intercooler if i get kr at about 12psi they will just pull that timing out?
I am not sure what the best logging software is. I am using AutoEnginuity and it does the job. It is not perfect and it is a little slow and it would be nice if it provided more data hits to make it a better source of information for fine tuning.
ok sounds good. this is the set up am going with tell me if its good or do i need n e thing else fmic,#44 multitec,255 lph pump, b/c, and bov. and my goal is 10-12 psi
that good or need somethin else?
