inline pump 4 sts
I mounted my in-line pump in front of the filter to the bottom edge of the frame rail. I took the filter out of its holder and moved it after the pump. My pump came with barbs and I clamped high pressure fuel line on them. I double clamped the fuel line onto the stock steel line. I left the filttings in the filter cut the steel line and double clamped the fuel line from the pump to it and then from the filter back to the stock fuel line. There was a write up not long ago by blue 01 I think that did the job using proper fittings and looked very good. The only thing I did not like about it was the 180* bends but they may not hurt the flow that much or at least I hope they don't.
Part # to hard plumb wabro in-line
Originally Posted by ogkevin13
looks really good i think am ganna do the same thing u did where do u get the power supply?
I hope that the install goes well for you.
ok sounds easy thanks for ur help whats the trigger switch for i tought it was just ground and power?
rednekferlife101
Sep 14, 2015 05:27 PM
