Injectors big enough?
Old Dec 5, 2009 | 10:26 AM
1BADAZZSS's Avatar
Originally Posted by krambo
Here is a "guideline" for injectors:
1. Take your target peak horsepower (FW) and multiply by .6
2. Take your resulting number and divide it by 8 (number of cylinders)
3. Take that number and divide by .9 (corresponds to a 90% IDC)
The final result is your desired fuel injector flow.
If you wanted to calculate a NA motor instead of your supercharged motor, you multiply by .5 in step 1 and for turbo, multiply by .625.
What if you are running E85, IE E85 takes 20% more to run then regular unleaded gas.
Old Dec 5, 2009 | 07:29 PM
krambo's Avatar
Umm, add "20%" to your end flow result. This formula is a guideline, not the be all end all; this is what it must be, type of thing. It is not my formula (I think FAST uses it alot) however I used it to size up my projects and it was very helpful. There are a ton of variables that are not included (fuel temperature, fuel type etc.) that is why it is a guideline...and for a guideline, it isn't bad at all.
Old Dec 13, 2009 | 09:44 PM
SRT10KLLR's Avatar
Former Vendor
Originally Posted by waterdog
I installed a used radix which had a 2.8 pulley and 44 lb injectors on my 6.0 lq9. It came off of a lq9 as well. The previous truck had a stock cam and manifolds with a free flowing exhaust. The injectors were at 75%. My truck has a 212-218 low lift cam and long tube headers. This cam isn't that big for a 6.0L, it idles like stock. I also installed meth inj using washer fluid because its in my washer fluid reservoir and I dont want 100% meth spraying on my windshield. Just wondering if 44lb injectors may be big enough, I dont want to buy 60s if I dont have to and I dont have a wide band yet.
If you find that you need 60lb injectors let me know(PM) as I have Plug n' Play Multech II truck injectors.
Old Dec 14, 2009 | 07:36 AM
waterdog's Avatar
Thanks, ill let you know.
adunphy
Feb 22, 2016 06:38 PM
Alco
Sep 4, 2015 04:08 PM
rojeho
Aug 8, 2015 07:20 PM
black6spdz
Jul 16, 2015 01:32 AM
jrplz
Jul 9, 2015 12:07 AM
