Injectors
Old Oct 30, 2008 | 08:42 PM
  #31
PSM's Avatar
PSM
How is the driveability for the 60 lbers? Do they not atomize the fuel enough for low rpm combustion?
Old Oct 30, 2008 | 08:50 PM
  #32
zippy's Avatar
It's not bad once you get them tuned in.
Old Oct 30, 2008 | 09:08 PM
  #33
PSM's Avatar
PSM
hmm define not bad... I've seen people put up with a lot thats "not bad". I guess I'm just fussy.
Is it bad to run injectors at or near 100%IDC?
What does running them above 100 do... they can't exactly quirt in more fuel can they
Ok done whoring up your thread sorry!
Old Oct 31, 2008 | 12:43 AM
  #34
SRT10KLLR's Avatar
Former Vendor
From my understanding anything above 100% just means that the PCM is commanding that much fuel but the injectors are not keeping up. Also, above 80% IDC the injectors are no longer linear and therefor no loner predictable.
Old Oct 31, 2008 | 03:52 PM
  #35
alanderson1978's Avatar
Over 100% IDC you get way lean way fast....This just happened to me because of a wastegate issue. Put me at 14.0 AFR at about 12 psi
Old Oct 31, 2008 | 06:14 PM
  #36
hog's Avatar
hog
100% duty cycle is the injector pintle help open, or static. Obviously if duty cycles over 100% are commanded, the injector cant flow anymore, the engine goes lean.
BTW injectors are rated at 100% duty cycle or help wide open at usually 3BAR or 43.5psi rail pressure. 50% duty cycle is 50% of the time open, 50% of the time closed.
peace
Hog
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
