Injector question?
Will the injectors from an 8.1L fit the 6.0L engine? If they fit, would they support 8 lbs of boost? Would I need a different harness and fuel rails?
Yes they will fit, but what you are looking for are 8.1 MARINE injectors. The are 43lbs/hr and a direct swap in. Should come close to keeping up with 8 lbs on a 6L depending on how many RPM you turn it, but that's about the limit.
Originally Posted by Gordy M
Thanks for the info, I thought the 8.1L ould fit but forgot they had to be the Marine type.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
bbowerman
Jul 26, 2015 10:57 PM
