Injector question?
Old Apr 2, 2007 | 10:57 AM
Gordy M's Avatar
Default Injector question?
Will the injectors from an 8.1L fit the 6.0L engine? If they fit, would they support 8 lbs of boost? Would I need a different harness and fuel rails?
Old Apr 2, 2007 | 11:11 AM
kbracing96's Avatar
Yes they will fit, but what you are looking for are 8.1 MARINE injectors. The are 43lbs/hr and a direct swap in. Should come close to keeping up with 8 lbs on a 6L depending on how many RPM you turn it, but that's about the limit.
Old Apr 2, 2007 | 02:47 PM
Gordy M's Avatar
Thanks for the info, I thought the 8.1L ould fit but forgot they had to be the Marine type.
Old Apr 2, 2007 | 02:50 PM
RandomHero's Avatar
they will fit but they won't flow enough for your needs they only flow at 36.4 at whatever our fuel rail psi si.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
blackdc3
Jul 7, 2015 07:52 PM
