Injector help for the 2.3l twin screw
Old Dec 12, 2009 | 05:55 PM
SincalT/A's Avatar
Default Injector help for the 2.3l twin screw
I need to know what injectors I jus bought?
What are the pro & cons for them in my build?
The main question I guess is will they provide enough fuel?
I bought these from a member on here that claims they are 60's at 58psi fuel pressure.I believe otherwise so I would like you guys help me decide.
The platform is a 4.8l with 212/218 .531 .531 114lsa W/1.8's mildly ported 241 heads which brings CR to about 8.8to1,Long tubes.A 2.3l lysholm twin screw puttin out 16-17 lbs.of boost.Right now at 11lbs I firmly believe its putting down around 500rwhp on a less then par tune.All this will be on pump gas.Return fuel system.
The injectors in ? are part#01D030B they have a blue stripe EV1 connector All black Lt1 style body.
Old Dec 12, 2009 | 06:04 PM
terravast4's Avatar
You are correct. Those are Delphi 42# injectors.
Old Dec 12, 2009 | 06:28 PM
phasemaster1's Avatar
Wow that sucks
Old Dec 13, 2009 | 12:13 PM
SincalT/A's Avatar
Originally Posted by phasemaster1
Wow that sucks
You are correct.
I know its going to be a struggle to try and get this resolved by the member too.So far I told him I would ship them back at no cost to him if he refunded my money.I think this is a more than fair offer.So does anyone want some brand new 42lb@43.5psi. injectors cheap?They are 48lb.@58psi btw.
Old Dec 30, 2009 | 09:29 PM
SincalT/A's Avatar
Bump for a certain member to read.Jus resolve this and it will go away.
Duane
Old Dec 30, 2009 | 09:52 PM
Mangled03gmc's Avatar
Baltimore Whore
Wow, I think I have heard issues with this guy before, but can't be 100% sure since we have had a bit of shitty sellers here lately.. Hope you get things straightened out..
Old Dec 30, 2009 | 10:01 PM
SincalT/A's Avatar
I think ill bump his for sale thread.
Also if anyone has info on if the injectors in ? would support the power im lookin to put down.(Which is about 650-700 fwhp)I would appreciate it.I think I know the answer jus making sure they're not magical 42's.
Old Dec 30, 2009 | 10:06 PM
Baltimore Whore
Holy **** your making that kinda power with a 4.8?? 42's arn't going to handle that.. 60's might be up in the IDC's Last time I logged my 60's were at a max of 74% and I am not no 700 fwhp
Old Dec 30, 2009 | 10:08 PM
DrX's Avatar
DrX
The 42s will be good to around 500hp. You will need real 60s, which will give you 68 at 58psi. Should be good to around 800 hp.
Old Dec 30, 2009 | 10:11 PM
SincalT/A's Avatar
I am currently running a 3 3/8 pulley.This puts me around 11lbs.The 2 7/8 I plan to run should bring boost up to 15-16 and no it will not slip.
